Question about Dryers
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Posted on Nov 06, 2012
  • Connie Crowder Nov 06, 2012
    Thank you Richard, it is a GE Model #DBVH512EF0WW
  • Richard Roth
    Richard Roth Nov 06, 2012
    Here is the motor for the model.http://click.linksynergy.com/fs-bin/clic... The part comes with a 365 day, any part, any reason return policy.
4 Suggested Answers
mccauleymr
SOURCE: When I try to turn on my dryer it just buzzes for
I had a similar problem; start the cycle and hear a loud buzzing but no movement of the drum.
I pulled off the top and back cover to reveal lint buildup inside the housing and around the motor. The belt was on properly. The vent coupling on the back was not secured properly, and was allowing lint to buildup inside the unit. I cleaned the inside the best I could and vaccuumed all around, trying to get the motor as clean as possible. Replaced backpanel (re-connected power) and the unit works fine now. I'm not sure exactly why it works, but it does. :)
Posted on Feb 19, 2012
  • 2696 Answers
SOURCE: Dryer won't start. Just makes a buzzing noise.
see if you can spin the drum by hand,if you can sounds like you have abad motor,or something could be stuck in the blower wheel jamming the motor and the belt broke but the sound is the motor,you need to get in there and look,let me know what you find and if i can help you with anything else
Posted on Apr 16, 2010
  • 22 Answers
SOURCE: buzzing noise, will not start
Your machine needs a new motor the start switch on the motor has worn out I have tried replacing the sart switch but the result is the same!
Posted on Aug 22, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
My dryer has burnt smell just buzzes but doesn't
Check the motor, it's sticking or already burned out
Mar 26, 2013 | Dryers
Model # 200PB101FREV00
Katherine,
Many times when a desktop is making a strange buzzing noise - it is due to a fan malfunction of some sort. Other reasons include a power supply that is faulty or possibly a bad internal speaker.
I would first check the fan(s) for the computer. Start by turning the computer off all of the way. Next, unplug the cords from the unit. You'll need to isolate just the computer tower itself. Next, you'll want to get some compressed air or a vaccuum and gently clean out the areas where the system case fan vents are. If you know how to open the case for your desktop, it wouldn't be a bad idea to make a quick visual check inside of the case for things that may be caught in the fans. Some desktops open via screws on the back plane, and some open with a pull tab/lever.
If cleaning out the dust doesn't resolve the buzzing noise - then you'll need to make sure that the noise is not part of the electronics. If you are hearing an actual electrical buzz and not a speaker or fan noise, then there is likely a larger problem with the computer. In that case - I would take the computer to a certified professional for diagnosis.
Another culprit of buzzing noise may be a CD/DVD drive with a disk stuck in it. Make sure that you have ejected the drive to ensure no disk is stuck in the drive.
I hope this information helps!
Nov 22, 2011 | Compaq Computers & Internet
When i tried to turn on the dryer, i get a humming / buzzing sound and the drum / motor doesn't spin anymore
Those symptons (humming/buzzing ¬ starting) are 99 out of a 100 times a sign of a motor that has locked up.
Gene
Aug 07, 2011 | GE Dryers
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
Kenmore 65611 electric dryer makes buzzing sound when press start but doesn't start drying process
heatman101
Jun 17, 2011 | Kenmore Dryers
My dryer will not work at all, it just makes a buzzing noise
If the sound is more of a hum than a buzz something has the motor in a bind or the motor has gone bad. Make sure you can turn the drum by hand and if you can not then check for something in the blower wheel.
May 28, 2010 | Whirlpool LER4634J Electric Dryer
Dryers Logo
520 people viewed this question
Top Dryers Experts
