Toshiba 27AF43 27" TV
Problem for Toshiba 27AF43 27" TV
White lines at top of TV
By alexlacelle on Jan 05, 2009
I have white lines at the top of my TV which come down approx. 2 inches. I've read around the site and found that it could be a problem with the Vertical Output. I took the TV apart, and noticed that this Capacitor (C521 on the board) had some white stuff that appears to have come out of it. Does it mean it's blown and that it is my problem?
I took some pics:
http://img.photobucket.com/albums/v287/2001championsr6/Image007.jpg
http://img.photobucket.com/albums/v287/2001championsr6/Image004.jpg
Any info on this would be great...
Best Solution
posted on May 05, 2009
Very Helpful)
ve6imb
Rank: Apprentice
Rating: 100%, 2 votes
I had the same problem with horizontal white lines about 4 inches at the top of my 5 year old 27AF43 Toshiba. Solution, I found by google was to replace C407 but no directions. Here is how I did it.
First is to locate a new polarized 100uf 35V capacitor. I was able to buy 5 of these at a local electronic parts store for $2.50.
Next is to open up the TV. Turn off the TV and unplug all wires, place TV screen side down, remove the seven large screws, three on each side and seventh a couple of inches up from the bottom and about nine inches in from side. Then remove the two small screws in the area where the cables plug in. Gently lift off the back cover.
Put a large magazine or newspaper over the bottom part of the picture tube to protect if from scratches.
Next is to pull out the cicuit board at the bottom of the TV, it's the only one. Clip the cable ties holding some of the wires to give more freedom of movement and then gently pull up on the board. It doesn't need any fidling with clips or tabs or such, just pull straight up. You don't need to disconnect any wires.
Then locate capacitor C407. It is black and marked on the cicuit board and is 3 1/2 inches in from the edge and right by the corner of a heat sink. It will have 100uf 35V written on it. Note which side is the negative (this is important). It will be the same side as the other capacitors close to C407.
Next is to replace C407. Take some measurements from the edges of the cicuit board so you can locate C407 (from the bottom) and then flip the board over and locate C407's leads. Draw a circle around its leads with a felt pen. Us a fine tipped soldering iron and a solder ****** to remove the solder. Be careful with this. Might take a couple of goes but eventually you will beable to wiggle C407 and it will come out.
Put the new capacitor in and make sure the negative is on the correct side (this is important). Solder the two leads and be very careful the solder doesn't bridge between the two leads. Let it cool for a few minutes then use a pair of side cutters to cut off the excess leads.
Slide the circuit board back and push gently down until it snaps into position.
Remove the protective magazine or newspaper.
Use a couple of new cable ties to replace the ones you cut.
Replace the back cover being careful that the power cord is positoned correctly into its little notch. Replace the two small screws and the seven large ones.
Reattach the cables. Cross your fingers and turn on the TV. With luck your white lines will be gone.
Good luck
Brian
VE6IMB
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 14, 2009
Not Rated)
ijklmn39
Rank: Apprentice
Rating: 0%, 0 votes
Same problem on a Toshiba 27DF46 fixed by replacing capacitor C407 (100uF 35V.) The faulty capacitor looked absolutely normal, no bulges or leakage.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 27AF43 27" TV
Questions and Unsolved Problems for Toshiba 27AF43 27" TV
Do you recommend Toshiba 27AF43 27" TV?
Answer
Answer
Toshiba model 27AF43 flat screen tv displays fine white lines across top five inches of screen.
Answer
Horizontal line at top. They are around 8 line space by .25 inch. Some station will emit signal in... (More)
Answer
i just got a toshiba tv...27af43..27". but i do not have the remote.pl help me as to how can i... (More)
Answer
What causes the picture to shrink and have black lines on each side,and the picture to be Jumpy ? Is... (More)
Answer
We have a toshiba 27af43 & when you turn it to AV to watch a dvd or play PS2 it displays the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 27AF43 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
