Question about Frigidaire Stove/Oven/Range Cooktop - 318079348
Frigidaire stove oven want come on model # FGF368GSJ
Oven will not come on
  • Official Brand Answer
  • 4,342 Answers
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Posted on Nov 06, 2012
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
How do I get a manuel for a frigdaire stove model number FW526W-1
sorry but they say that is not a valid number .if you can provide a good photo of them perhaps someone will know and share that information with US
Oct 16, 2015 | Frigidaire Stove/Oven/Range White Cooktop...
How do I reprogram a Frigidaire stove/oven after replacing the eoc?
Thank you for your post, Roy!
Based off the information you have provided you need to reprogram your Frigidaire range because you have replaced the oven control. The best way to reset your range is to disconnect power from it for roughly ten minutes. If that does not help resolve your issue you may need to have another electrical component changed and I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Mar 28, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
Oven doesn't let steam out
Thank you for your inquiry, friend!
From the information you have provided your Frigidaire range is not allowing steam to come out. If your vent is blocked it will not release the hot air or steam. Could you provide me with your model number? You can locate the serial tag (which lists your model number) on the door frame of the lower drawer. With the model number I can provide you further assistance. -Matt
Mar 15, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
Replaced element on frigidaire oven and oven still not working
Good Afternoon Friend,
I understand you've recently replaced the elements on your Frigidaire oven and that it is still not working. May I have your model number please? The serial tag, which lists your model number, is normally located in the storage drawer, on the right side if you have a range. If you own a wall-oven please check the front of the oven, on the left side, as you open the door. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better determine what may be causing the issue at hand. Thank you! - Z
Sep 07, 2014 | Frigidaire Stove / Oven / Range Cooktop...
VF72824070
Hello Anonymous, that's a great question!
In order to provide you the correct cleaning instructions for your Frigidaire range, I would need your model number please. The serial tag, which lists your model number, is normally located in the storage drawer, on the right side. Thank you and I look forward to hearing from you. - Z
Aug 30, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
How to turn oven on on a Kelvinator Cookarama Oven (Older model)?
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
Jun 02, 2014 | Kelvinator Refrigerators
What does a F550 code on a Frigidaire Stove mean?
That means that the oven control board is having problems. Replace it.
Feb 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
The left rear stove element went on High and would not turn off by controls, why? There was an F550 code that came earlier with the oven?
My range was doing the same thing. I finally called the Consumer Protection Agency and reported it. It launched a national recall. With their help, Frigidaire replaced my range. On Easter 2014, the new one did the same thing. Burner turned on by itself, to 8.5 with knob in the off position. We had to unplug it. Frigidaire once again did not care. I contacted the CPSA again - they are investigating. I will NEVER have another Frigidaire Range. Check your model number against the recall information. Don't trust it! It is a fire hazard.
Frigidaire Stove/Oven/Range Cooktop - 318079348 Logo
178 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
