Question about Proform 6.5q Treadmill Walking Belt
House fuse triping off problem
After plug-in to start it. on push of safty key home fuse trips of. moter is o.k. cotroller board seems to be o.k. home fuse is also sixteen AMP. only on controller board the voltage between red and black points for motore flactuates from 224v to 170v on testing.
3 Suggested Answers
SOURCE: I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
Posted on Apr 26, 2010
SOURCE: Recently purchased the Crosswalk 570. Assembled
recently purchased a crosswalk 570 treadmill and used it and it worked fine but when we tried to use it today the machine made a strange noise under the hood. we noticed that the belt on the track was slightly rubbing against the hood. How can we fix it?
Posted on Feb 25, 2011
When I plug in (and switch on) the hostess trolley it trips the electric in the house. However, works perfectly in another house.
sounds as if your home power distribution / Fuse board has an earth leakage trip and is sensing a leak on the trolley, perhaps the other house is not so well protected, or the Earth Leakage Circuit Breaker ( ELCB) trip is faulty. It would make sense not to use the trolley until you have had it checked out
Jan 02, 2016 | Televison & Video
How do you change the fuse in a window unit?
some uneit have a fuse in the electronic board, i would put a new electric plug first is it 220v or 110v go for the plug first
May 24, 2014 | LG LWHD1800R Wall/Window Air Conditioner
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
Ariston a1600wd wont turn on
Before you change fuses, do you have an internal fuse board or RCD system in your home? Sometimes, an individual RCD can trip out, locking off sockets. Some sockets are individually set up for up and downstairs in a house, or different rooms. If you have a board or RCDs, check them out :)
Nov 18, 2017 | Ariston Technologies Washing Machines
Hi, my washer dryer keeps triping out my main fuse box. I loaded the dryer before going out and came home to find it had triped out. I've change the fuse in the sucket and the plug but it keeps happening....
'Resetting' the machine(even if it has a reset) won't fix the problem. The most likely reason for the fuse tripping out is because there is a fault inside the machine. Probably because there is a water leak some where. There are a number of areas to be carefull of....Best advice is to get a tech......Nomess
Apr 12, 2010 | Washing Machines
Second hand Fisher & Paykel keeps tripping power off
sound's like you have dead short to ground in the start mode of the compresser.
Nov 22, 2009 | Maytag MSD2651 HE Side by Side...
Electric Furnace
There could be a small fuse on the cotrol board
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
My ULine icemaker just started triping the GFCI plug.
Ground fault should not be used when you have a compressor plugged to it. The start amps can trip a ground fault. You can try to plug the unit on a regular outlet and if it doesnt trip the breaker then unit should be good. You can try to replace the ground fault if you need it (but make sure you have a higher amperage on the new one.)
Dec 23, 2008 | U-Line Icemaker
Everything is operating fine but the furnace wont fire. you can hear the gas kick in for like 3 seconds and kick back off when it doesn't ignite. then after about 5 tries it shuts down and the red light...
COULD POSSIBLY BE A BAD IGNIGHTER.I DON'T KNOW THIS SYTEM BUT THE SAFTY PROTOCALS ARE WORKING.THE THERMOCOUPLE(IT DETECTS HEAT)IS TELLING THE BOARD IT HAS NO IGNITION,THEREFORE KEEPING YOU FROM BLOWING YOUR HOUSE UP.IF IGNITION HAS'NT HAPPENED WITHIN A FEW SECONDS IT SHUTS THE GAS OFF.IF YOU DON'T KNOW WHAT YOUR DOING DON'T MESS WITH IT,.IF YOU GET INTO THE WRONG THING YOU WILL ALLOW NATURAL GAS OR PROPANE TO LEAK INTO YOUR HOME(THIS IS A BAD THING)THE COTROL BOARD BLINKING IS A TROUBLE CODE.USE YOUR OWN JUDGEMENT.IF YOU NEED FURTHER HELP CONTACT ME.THE IGNIGHTER IS EASY TO CHANGE.ENOUGH SAID!!!!!
Nov 08, 2008 | Frigidaire Heating & Cooling
Proform 6.5q Treadmill Walking Belt Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
