Question about Southern Telecom Emerson Bluetooth Headset Black Wireless Headset
Bluetooth wont turnon new unit out of box
Emerson bluetooth em236c redlight goes out when charging i cant seem to get red / blue light as described in instructions to turn it on. Is this a charging problem?
  • Anonymous Mar 18, 2014
    I just bought a nemo digital Yankee bluetooth in amazon and I'm having trouble charging it it turns red while it starts charging then it stops charging when the red light goes off not knowing if its charging
Pardon me if you have already tried this but with my em236c I had to hold the Answer/End button for about 15 sec before it flashed red/blue. The manual doesn't say how long to hold it. It took a couple of tries for me. Hope this helps.
Posted on Jan 12, 2009
When I plug up the bluetooth to charge the red light appears then it blinks blue red does that mean it is charging or not because it is not working with phone
That might meaning that's it's draining the residual charge left on the battery, before it can be charged, but if it does this for more than an hour, your battery is "toast".
Aug 28, 2014 | Universal QuickCell Q7 Bluetooth Headset -...
How to get my new Bluetooth set-up
So, what else can I tell you. You yourself have discribed that your headset is defective. So, being a new device, return it to be changed for a new one.
Jun 03, 2014 | Apple Cell Phones
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
ON putting my Bluetooth hands free Nokia BH 101 only the red light goes on blinking. I have put it on charge overnight still i cant switch it on. How should i fix this ?
SO!! FINALLY! Connect headset to the charger. Wait for 1-2 mins, then HOLD VOLUME UP key + SWITCH ON KEY for.. donno i waited for 30 sec, then looked at redlight and suddenly saw a GREEN LIGHT lightning, but it's so hard to see it. I'll try to do a photo.
Dec 18, 2010 | Nokia BH-104 Bluetooth Headset
I HAVE A NOKIA E71,BUT MY EMERSON8227A-BH08R NO CONNECT, NO FIND A BLUETOOTH
Emerson EM277.
Make sure unit is fully charged (no red indicator when plugged in).
Press and hold the power button until indicator rapidly flashes red/blue back and forth.
Search for device again. More detailed instructions here.
http://southerntelecom.com/emersonsupport/downloads/EM227.pdf
May 06, 2010 | Southern Telecom Emerson Bluetooth Headset...
Pair bluetooth em227 with my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Mar 05, 2010 | Southern Telecom Emerson Bluetooth Headset...
I cant get my plantronics ex 233 bluetooth to connect to my ps3
when i charge my bluetooth, the light is red for a few minutes but it goes out and its not charging anymore. Please help
Mar 04, 2009 | Plantronics Stereo Earbud Headset for Use...
Southern Telecom Emerson Bluetooth Headset Black Wireless Headset Logo
337 people viewed this question
Top Southern Telecom Radio Communications Experts
shaun taylor
janman
Are you a Southern Telecom Radio Communication Expert? Answer questions, earn points and help others
