Question about Toshiba 57H81 57" Rear Projection Television
Vertical blue line not in vocus
We have blue shadows to the right of all objects on the television. When we complete the touch screen focus, we get an error msg and the vertical blue line is not straight, it curves to the right. We need to know what part to order to fix this.
It sounds like you lost a convergence amplifier. There is also the possibility that a resistor on the main circuit board that goes to the horizontal control circuit for the blue CRT/deflection yoke may have a cold solder joint. These circuits generate a considerable amount of heat and can weaken solder joints over time. Try bumping the side of the television and see if the blue line changes or if the blue color returns. If so, then it may very well be a cold solder joint that needs to be touched up. This is one of the first things that an electronic tech tests for - sounds crazy but I've fixed literally thousands of televisions this way. Good luck.
Posted on Jan 08, 2009
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Blue shadows
yes its the problem of convergence
and for reaar idea of what to replace on the main board and how to replace and how the components look and what is called what and what tools you require to do it yourself and how to fix it
please check the above link by clicking it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jul 21, 2008 | Sony KP-53XBR45 53" Rear Projection...
Blue shadows/ghosts
how old is the tv ??
if this tv is older than 5 years it may need to refill the liquid on the proyection bulbs and/or could have contaminats in the fluid causing the ghost and to fix that you will need a professional person to do it
Apr 03, 2008 | Toshiba TP55H60 55" Rear Projection...
Picture problem Model Toshiba 61H71
Hi, convergence circuit has failed, IC`s and probably 1 or 2 precision resistors will have to be changed, not really something you can fix if your not an electronics tech, BMW Rider
Jan 09, 2008 | Toshiba 61H71 61" Rear Projection...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
