Question about Coleman Powermate Premium Plus 6250W Portable Generator
When it starts it has a lot of white smoke and after running for a few minutes spits sparks ot of carburator
    Prodigy:
    An expert who has answered 500 questions.
  • Coleman Expert
  • 573 Answers
The fuel mixture is way too lean, or a burnt valve. Check the spark plug color it should be bisuit brown, if it is grey then suspect the above.
Posted on Nov 15, 2013
What does white smoke mean?
With a petrol engine, water/coolant is being burnt due to blown head gasket.
Jun 17, 2014 | 2001 Nissan Altima
The oil was low in my Cub Cadet SLT 1550 so i filled it up, and after about 5 minutes the engine started smoking blue, smelled like oil and after a few seconds it turned really cloudy white
remove the spark plug and try and crank it over see if oil spits out you might have dumped it in to fast and it went threw the breather
Jul 10, 2012 | Garden
1996 Subaru Legacy GT - Twin Turbo, manual trans: started spitting a lot of white smoke out of the exhaust. It did that when the car started then seemed to be ok when in idle but when on take off and...
Expect to hear your head gasket needs replacing, at a minimum. White smoke means it's burning coolant. How much it will cost I can only guess, but usually a head gasket repair- a few hundred dollars-it's pretty time consuming and labor intensive, especially with all the turbo stuff that could be in the way. Good luck.
Apr 06, 2012 | 2012 Subaru Legacy 2.5i Sedan 2.5L 4-cyl....
50cc scooter spitting oil out of exhaust
I guess you people cant read, he said it is spitting oil out the exhaust, thats has nothing to do with spark plug or carb cleaning...the oil injector is stuck open putting to much oil into the mix....
Mar 13, 2012 | Motorcycles
Lawn mower running rough
adjust the carby. also u might want to replace the diaphragm in the carby. might work wonders
Mar 31, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
My johndeer 14sb starts on the first pull but spits aand sputters and won't throttle up. Does not backfire but when I pull out the spark plug in five minutes of running it is covered in black suit
you need to adjust the carburator and look at the linkage for the govenor to see if it is sticking, if you need more help on this post here for more info.
Aug 13, 2009 | Garden
White smoke on start up on 1998 mazda 626
Hi
Lots of things to check
?Leaking head gasket
Does it use brake fluid
Start engine only fo a few seconds, shut down, remove all spark plugs to see which ones are fouled
Aug 10, 2009 | 1999 Mazda 626
Oil causing a problem?
Sound as if you have too much oil in the machine. Anytime you see white or lite gray smoke it is a sign of too much oil. Before you go through the routine of cleaning the oil out of every nook and cranny, try unscrewing the spark plug and clean it with a soft rag. It would have oil on it preventing the machine from starting. If this does work and there isn't a lot of oil in the gas tank now, just continue running the engine until the smoke clears. It won't hurt anything. But if cleaning the plug doesn't help you will have to empty all gas and oil from the gas tank, refill with new gas, squirt a little gum out carb cleaner in your carb to remove any oil there (this can be done when you try to restart the engine). Remember, when you are mowing grass if you are mowing on a hill) of any knd, make sure to turn the mower so the gas tank is on a higher level than the oil.
Jun 18, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Coleman Powermate Premium Plus 6250W Portable Generator Logo
82 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
