Question about Alpine MRD-M1005 Car Audio Amplifier
"cur" error mrd-m1005
Hi guys i just got this amp attached to two 12 inch type r subwoofers. It lasted for about 10 minutes then went out and it says cur. Do you know what i can do?
  • 2 more comments
  • blueranger Feb 17, 2008
    it says cur ... i tried checking all the fuses they look good the ground wire seems to be fine what should i check .... it worked for the longest time was going good then stopped said " CUR " and now it works everytime start my truck untill turned up loud ... then it cuts out and says cur.... i tried fixing all these things... Im really confused...
  • str8hustilin May 17, 2008
    i have the same amp and it shuts off and says cur then i shut off the deck and turn it back on it works fine untill i turn it back up then it shuts off again
  • c-taylor-80 Aug 28, 2008
    My alpine v 12 does the same thing . CUR flashes and the subs cut out . I just wired up the amp . What could have gone wrong ?
  • Anonymous Sep 08, 2008
    hooked up the amp 2 a 15 in woofer and it shuts off and reads current. smells burnt
U guys the cur stands for current witch means its starving for power so u could add a 2nd battery or upgrade ur alternator the battery doesent haved to be an expensive 1 just put a good strong batt in the trunk wire it in with ur wires u already have back there then run ur + and - straight off that batt and use atleast 4 guage trust what i say been in this game 10 yrs and this is how i feed 7 kids thanks
Posted on Feb 13, 2010
BUT MY AMP KEEPS SAYING CUR AND I ONLY HAVE 1 TYRE R IN MINE AND ITS KEEPS SAYING CUR I REMOVE THE GROUND WIRE TWICE AND IT KEEPS SAYING IT I HAVE A 8 GAUGE AND EVERYTHING THIS **** JUST DONT WANT TO WORK WITH ME SO TELL ME PLEASE
Posted on May 05, 2008
  • BRAYLON BELCHER May 05, 2008
    I HAVE ONLY ONE AND IT KEEPS SAYING "CUR" WHAT AM I SAPPOSED TO DO BECAUSE I ONLY HAVE ONE TYPE R AND A 8 GAUGE
I had the same problem double check your grounds, thats all it was
Posted on Oct 30, 2008
Be sure you havent already burned voice coils in the sub....id also reccomend only running one of those type rs in a ported box it will run one no problem without the CUR error
Posted on Apr 26, 2008
"CUR" basically means there is a short in the wire... i had that problem with the exact same amp... except mine kept cutting in and out and eventually just didn't get any power at all. use a voltmeter on your inline fuse on your power wire... my install kit came with an 80A fuse... what happens is if your amplifier draws enough amps... say 70-75... it will melt the connecters on the fuse but wont blow it... that was my problem... switched the fuse and everything worked fine... if thats not it, check your ground... or just make sure your wires arent fried. i have 6 gauge wiring for mine and it does just fine, 8 gauge should be changed for this amp.
Posted on Jun 20, 2007
I just purchased the dual xinbp210 and don't know what size amp i need?
  • Enclosed subwoofer with dual 12-inch speakers; measures 27.5 x 14 x 15 inches
  • illumiNITE technology constantly illuminates the speakers with blue LED lights when in use
  • Handles 600 watts RMS power, 1100 watts peak power
  • Carpeted enclosure, plexi subwoofer viewing window
  • Dual 12-inch Low-Q optimized dri
Mar 26, 2015 | Cars & Trucks
My legacy 12 inch subs are making a crackling sound what can do?
Hi rodneybarton
The problem of your unit may be its amplifier. You need to open the box and inside of it, there is a component that attached on the heatsink you need to replace that one. or better send your unit to qualified technician.
Dec 29, 2013 | Jl Audio Car Audio & Video
My subwoofers in my car are not working properly, I have a Kenwood Hu, 1000 watt 2 channel earthquake amplifier brand new, 2 Sony Xplod 10 inch subwoofers and a pioneer 12 inch subwoofer. the problem is...
I just got done with 10 others like this with the same problem, just look at some of my other solutions to see what you will be doing. Basically you need to upgrade your entire charging system to run these amps, You guys are not even considering the power draw that it takes to keep these things running at full power! You need to plan out your system way before you start to buy things to make sure that you will only have to install it once and do it correctly. It all starts with the power available from your alternator. You will have about 40 to 60 amps of left over current to use from a stock alt after it has to charge the battery and power the car while driving. That means you can have a head unit drawing 15 amps and a sub amp that will draw 35 to 40 amps before you will need to upgrade your entire charging system. Failure to do this will result in Batteries lasting 1 year a new alt every summer, your amps will burn up the insides a few times before you realize the importance of this all.
Mar 30, 2013 | Car Audio & Video
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
I dont have any cosmetic problems with my subs .. but i have 4, 12 inch hifonics olympian subs in one sealed box. and i cant find any specs on them at all.. do you know the watts and rms wattage and how...
look on the bottom of subwoofer should say like olm2412 olm1612 olympus the 1612 is the rms and speaker size 2412 is 2400 rms and the 12 stands for 12 inch subwoofer.i think thair is only 2 modles . also u have 4 u would need a 10,000 rms amp if thay are the olm2412s or 6,000 rms amp to push 4 olm1612. as far as box building info i think you should call maxxsonnics. 847-540-7700 talk to mike
Mar 03, 2010 | Hifonics W-124 Olympian 12" Subwoofer Car...
Guys i have a problem on my pioneer deh-50ub that i put a vide 12'' subwoofer with amplifier and it wos working good for 10 minutes and after theat just comed to silence... i mean the rca plugs that...
your pre-amp output has failed.
it will require repair.
use your voltmeter and measure the voltage from the RCAs.... it should be approx. 2.5v
If nothing - it is in need of repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 11, 2009 | Pioneer Car Audio & Video
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Mar 08, 2008 | Car Audio & Video
How to connect pioneer reviever to velodyne subwoofer
Look for the sub pre out on the back of your amp and connect a sub cable to this and next to the LFE or phono type input on the back of the sub ,if it has two inputs left and right pick the left side ,set the cross over to suit your system and speakers,if you are not sure set the cross over to 80 hertz,this is a thx standard.
hope this helps.
CABLE GUY.
Dec 27, 2007 | Velodyne DPS-12 Subwoofer
Alpine MRD-M1005 Car Audio Amplifier Logo
1,165 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
