Question about Keurig B60 Coffee Maker
Keurig d60 I must hold the handle for it to work
I used the external (grey insert) in order to use my own ground coffee. When I returned the black insert I now have to hold the handle down in order for it to be ready and start brewing. It's almost like it isn't seated properly but I can't find the problem?? Help! I love the machine but don't want to have to stand their all of the time.
  • Anonymous Jan 06, 2009
    I have one grey set-up that is used with a filter screen cu for grounds and the original black k-cup holder setup that was originally in place. It almost seems like it is not sitting int he holder all of the way??
    Thansk for your continued help.
  • David Shaub May 11, 2010
    Did you also change the drip funnel below the coffee grounds area? The one used for pods is different than the one used for the grounds attachment.
SOURCE: Keurig B50 Ultra brewer
This is a known problem with the B50 which Keurig will acknowledge if you press them hard. Some users have suggested trying to clean the check valve just inside the water outlet but the best solution is probably to call customer support, complain like crazy, and take the discount on a new machine that they will offer you. Apparently, this problem occurs much more often with the B50 than with more recent models, which may explain why it isn't on the market anymore.
Posted on Jan 23, 2008
SOURCE: keurig B50
This didn't work for me, but I saw that it worked for someone on another forum, so here goes...
If you feel up to taking the bottom plate off your B50, take it off and look at the two connectors (blue & red wires) going to the green part in the center. The vibration of the B50 may have shaken them loose. Reseating the connectors may fix the problem.
Like I said, though, it didn't work for me. Still no love from the B50. It's just over 2 years old, though, so it's out of warranty. Maybe I'll see if I can weasel a B70 for Valentine's Day.
Posted on Feb 01, 2008
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
espressonist
  • 1711 Answers
SOURCE: keurig does not brew the large cup of coffee, only
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
  • 3 Answers
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Posted on Dec 31, 2010
Looking for main large insert for k cup holder
I do not believe so. When you have a bad machine Keurig has you return that part to decommission your old machine instead of making you ship the whole machine back.
Apr 04, 2014 | Keurig Coffee Makers & Espresso Machines
Dishwasher melted black plastic insert to hold k-cups
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
May 31, 2011 | Keurig Platinum B70 Coffee Maker
When ready light is on and k-cup is inserted and handle lowered, pump starts but no water pumped
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Apr 18, 2011 | Keurig Special Edition B60 Coffee Maker
B-60 Keurig. Does not give proper fill. The steam is weak.Stops in the middle of the filling cup process. Works fine if I just run water through it. Have descaled numerous times per Keurig instructions. I...
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Feb 10, 2010 | Keurig B60 Coffee Maker
When using the basket for your own coffee - the coffee grounds go everywhere including in the cup. How do you stop that
Try pushing down on the handle while the Keurig is brewing. Mine doesn't seem to push down hard enough on the "make your own" kcup. It just takes a little downward pressure while the water is being forced thru the coffee.
Jan 25, 2010 | Keurig Elite B40 Coffee Maker
MY KEURIG IS BLOCKED AND THE WATER WILL NOT COME OUT
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
Apr 04, 2009 | Keurig Elite B40 Coffee Maker
Handle is pushed out
Are you using the pressurized filter baskets? My 2 1/2-year-old SL70 recently started doing the same thing, and I think I have narrowed the problem down to the filter basket (it works fine with a non-pressurized basket). I've ordered a new pressurized basket. I can't guarantee that this is the answer, but you might try it.
Feb 12, 2008 | Solis Crema SL-70 Espresso Machine
Filter problems
You put the gadget in just like a k-cup. Lift the handle insert the little plastic screened cup just as if it was a k-cup and off you go.Make sure you have it tightened or you may get grounds/
Jan 13, 2008 | Keurig B50 Coffee Maker
Keurig B60 Coffee Maker Logo
231 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
