Propane fireplace lights slowly with little "explosion"
4 Suggested Answers
  • 6 Answers
SOURCE: Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Posted on Dec 02, 2008
  • 3077 Answers
SOURCE: light soot around propane fireplace vent
burners burning yellow , in complete combustion , blocked air ways to burner , it needs a service soon as poss
Posted on Jan 12, 2009
  • 250 Answers
SOURCE: my propane fireplace pilot light wont stay lighted
Most gas valves have a flame sensor, which is a metal bulb at the end of a wire. The pilot light heats this bulb, and the valve stays open because there's a flame. If the flame has been out, you'll need to hold down the pilot light button for as much as two minutes after lighting the flame to allow the flame to heat the flame sensor up enough to keep supplying gas when you release the button.
Posted on Mar 17, 2010
Ven tfree propane fireplace will not stay running after being ignited
You may have one of several issues that can cause this ...
1. your pilot assembly could need replacing
2. you may not have enough ambient air flow and the oxygen sensor will shut it down
I suggest you have a qualified technician come out and inspect the system to see where the real issue lay. They will have to light it and see it burn to rectify the issue.
Jan 25, 2014 | Procom Dual Fuel Vent-Free Fireplace with...
Pilot light
I have a heatalator gas fireplace and the pilot light goes out after 2 to 3 day
Jan 05, 2014 | Mr. Heater Mr Heater Portable Buddy...
My fire place elecric starter won't work after running out of propane
Most likely, you need to "bleed the line". The new propane needs to travel to your fireplace, but you have a huge air pocket in there now since it ran dry. It takes forever for the air to "bleed" out through the tiny orifice of a pilot light, especially if the distance from the fireplace to the tank is far.
Jan 28, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Fireplace propane smell
I would change the reg for a new one .You should only get a small hiss from the breather hole .
Oct 23, 2017 | Heating & Cooling
I need to get a manual for a Charmglow electric fireplace Model # CGN250TED-C 25,000 BTU Pure Comfort solutions and I cant find a website, i need to know where to change it from natural gas to propane. ...
I am almost totally confused. You started out saying you have a Charmglow Electric Fireplace. Then you said you want to change it from natural gas to propane.
Could you please be a little more specific in what you have? So I can help you. As Charmglow only makes Electric Fireplaces. No gas ones.
Thanks, I look forward to hearing from you.
Aug 10, 2011 | Williams 2509612 Ceramic Mid-Size Heater
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Slow igniting gas fireplace
vermont casting company had filed bankruptcy, company doesnt stand behind product, just attempted to get replacement parts....company states not available....may need entire new unit....i think the better business b...needs to be notified.
Dec 11, 2009 | Vermont Casting VCS4017 (NG)
Light soot around propane fireplace vent
Dec 22, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
227 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
