Question about Jamo Audio Players & Recorders
I need a replacement woofer for a jamo C 803 speaker.
Its an 8 inch woofer, single speaker, markings are: 110175 000301 FSBA2A065-0401 061228 716524 The speaker coil appears to have 2 sets of wires going to it It is just a woofer, no other speaker elements are integrated into it.
  • 124 Answers
SOURCE: woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Posted on Jan 04, 2009
SOURCE: Jamo Cornet 90 IV Speakers - Woofers need replacement
I had the sub woofer problem what i did was i found the fuse in back of the unit i took it out with a srew driver. I looked in the light to see if the tube had a smoke shot in it and it did then i got some aluminum foil just a tiny piece and put it around the tube and low and behold my unit pop back on what a relief. The foil is for testing only you need a fuses to not cause a fire!
Posted by charles on Jan 12, 2009
Posted on Jan 12, 2009
  • 19 Answers
SOURCE: sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Posted on Apr 03, 2009
dunnbiker
  • 8546 Answers
SOURCE: replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
Posted on May 19, 2009
  • 133 Answers
SOURCE: No Sound from Jamo E6 Sub
More likely there is a bad solder connection or a bad connector contact inside the unit, could also be a blown or dried up electrolytic capacitor.
Check the line signal input plugs, if they are soldered directly to the board then check the solder around the pins - if it has circular cracks, you need to resolder the pins.
Also check any other components on the board for such cracks on the pins, including internal connectors, disconnect, clean the pins if necessary and reconnect them.
If any electrolytic capacitors have a bulged top, they are blown and need to be replaced.
It could as well be something else, but your description suggests either a fault at the input connectors or some trouble with the input signal level sensing circuitry (no signal to the sensing circuit may be caused by connectors, no response from the sensing circuit may be caused by bad capacitors or other faulty components in or around that section).
Hope you can find out what it is and fix it...
regards
3rq8 (Triarcuate)
Posted on Sep 11, 2009
What is the impedance of the JAMO A3SUB.3 speaker?
22K is the impedance listed in the specs but you may have to look on the actual speaker itself to get the impedance of the physical speaker.
Sep 15, 2012 | Jamo HOME THEATER PACKAGE, 4 X A320,...
Need to replace 5.5" woofer in Jamo S426 floorstanding speaker
contact maplin electronics they are really good at replacement units.
Jun 30, 2012 | Jamo S426HCS3 5pcs Home Theater Speaker...
15PLB76 15 Inch 800 Watt Woofer Car Speaker: what subs will be good to fit in my gmc sierra sin...
single shallow with a sealed box it would sound great!! no air tombs they **** thats called ported they really ****
May 17, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
I own jamo speakers CL 30. One of the woofers is broken. Can i find anywhere one woofer to replace it?
Best to have it reconed ! The speakers need to be matched pair.
If you are using these for music instrument(s) make sure they are intended for that use. Home stereo speakers won;t take the power that music instrument speakers are designed for by a factor of say four.
If these are mis-applied, don't waste money repairing, but buy instrument grade cabinets.
Dec 26, 2009 | Music
Jan 12, 2009 | Audio Players & Recorders
Jamo Cornet 90IV
not sure what size you need but dayton audio subs are pretty killer check them our parts express usa, i a have a set of realistic mach ones with one of my drivers blown i did some searching and found parts express, due to rave reviews and the specs on what i look for in subs dayton is the way to go,happy hunting-z
Jan 10, 2009 | Jamo A4SUB Car Speaker
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
Steve
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
