Question about Bosch Washing Machines
How do I reset Bosch aquastop - Bosch Washing Machines
    Top Expert:
  • Bosch Master
  • 9,472 Answers
Unplug it for 30 mins.
Posted on Nov 06, 2012
  • Graham Elsmore Nov 06, 2012
    Left it switched off overnight still no go
What is aquastop
I presume that when you say it wont stop running, it's the empty pump that is running. This is an anti flood protection. Water from a spill has got into the base of the machine and tripped the flood protection sensor. To cure the immediate problem, pull the machine out and tip it on it's side or back about 45 degrees and the water in the base will run out and the flood protection will reset. The real question is though, how did the water get INTO the base? Most common is that someone used household detergent instead of dishwasher powder or tabs and the foam it created worked its way into the base and then turned back to water as it settled. If this is the case, the tip sideways will be a permanent fix. If not, you will need to trace and cure the leak
Sep 23, 2015 | Bosch Dishwashers
What does E-14 in Bosch Washing Machine mean?
E14 stands for an error code concerning the flow meter. This is a sensor which mesures if enough water comes into the machine. There are several causes. Did you open the faucet enough or is there some dirt in the sieve between the aquastop and the faucet?
Jun 16, 2015 | Bosch Washing Machines
Do you have a user's manual
The manual is found here:
Bosch Order Management System LINK:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
You can also find these downloadable pdfs at this link (for your same model):
IU - Instructions for Use
SI - Short Instructions
In - Installation Instructions
PT - Programme Table
RP - Recipes
SP - Supplement
Jul 16, 2014 | Bosch 500 Series SHP65T55UC Fully...
Bosch SilencePlus shows E:15, Aquastop, and Watertap!
Hi Greg,
E15 on the Bosch units indicated the base switch is activated. There is a safety switch which will activate the drain pump to avoid the base overflowing. Basically you either have a leak or possibly rodents living in the base of your dishwasher.
Easy way to check is first make sure no water is inside the washing area or sump (where the filter is). You will have a dribble there which the drain pump won't pump out but make sure it is mostly empty. The dishwasher always drains at the beginning of a cycle if you need to manually activate this, just turn you tap off so it doesn't try to fill. unplug your dishwasher then pull the machine out and place some old towels along the base and tip if forward. If water run out from the base then you got a leak.
If you are a bit handy then you can take either the front kick plate and cover off or a side panel to look in the base. The float switch is a polystyrene disc which raises and hits a micro switch when the base fills up.
Common place for these to leak is the sump, wash motor or water path / distribution unit. Look for chalky white residue around the seals. Depending on the age of your unit some parts are more serviceable than others. Bosch are pretty good with spare parts so you should be able to source most items you need.
If you are not handy or technical and are concerned about taking on this work, call in a technician. Remember disconnect power before attempting any work. please.
I hope this helps.
Apr 13, 2014 | Bosch Dishwashers
Can't find SGS43t62 float switch assembly
The float switch in most Bosch dishwasher is part of the Aquastop circuit found in the inlet water hose connected under the kitchen sink. Refer installation instructions at this page. Type in the model number and download it.
Dec 06, 2012 | Bosch Dishwashers
Dishwasher Bosch SRV3303 can't fill the water
Aquastop valve was damaged. Nominal resistance is 2000 (4000) Ohm depends on variant.
Aug 25, 2009 | Bosch SRV53C03UC Built-in Dishwasher
Drain was clogged and the dishwasher overflowed. It's a 10yr old Bosch dishwasher. Now water won't flow into the dishwasher but it runs through the cycle and dishes arent clean.
Probably the aquastop (if you have one). We have a similar problem after our owerflow. The dishwasher is starting and running through the programs but no water is coming.
Jul 31, 2009 | Bosch SHU9915UC Dishwasher
Siemens 1433 Washer - Aquastop
I had the "pump blocked" message, and we had the pump replaced after the technician took a look. He said the washer had been overused (we had run it 4 times a day for 8 months).
Jan 13, 2008 | Siemens WIQ1433 Front Load Washer
Washing Machines Logo
1,432 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
