Question about Hunter Ceiling Fan Light Remote Control
Need to relearn ceiling remote fan code - Hunter Ceiling Fan Light Remote Control
2 Suggested Answers
wiringlunati
  • 576 Answers
SOURCE: I need a remote
You can buy a remote kit at most electric or home improvement stores. It will come with instructions and needs to have the receiver installed in the canopy of the fan itself. They usually have dimmers for the lights on them, so do not use CFL bulbs in the fixture. Lowes sells one made by Harbor Breeze for about $30-$40. Good luck.
Posted on Feb 27, 2010
Testimonial: "Air horn"
Need code for Concord ceiling fans
You have this backwards. The code is stored in the remote. The receiver is located inside the fan housing. You can try removing batteries from the remote, pressing all buttons to eliminate the possibility of a stuck one, reinstalling batteries (or installing new ones) and testing operation. If no results, disconnect power at the ceiling fan source, not the fan itself. Pause briefly, reconnect power and test operation.
Sep 02, 2014 | Concord Fans Dryers
Just replaced the battery remote will NOT work.... I have a very high ceiling.... this is getting annoying.... when I press the remote I get a red light wether I ask for fan or light.... light just blinks...
Some remotes have a learn button in them, when it lose its power you need to relearn it. Hold the small button for about 5 seconds, to reprogram it with the receiver. If it doesn't work ,then your receiver may need to be replaced.
Sep 03, 2011 | Hunter Ceiling Fan Remote Transmitter...
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
I need a remote
Feb 27, 2010 | Hunter 23827 Classic Original White 42"...
My ceiling fans original remote is broken adn I need to get a code to set the universal remote to turn on/off my fan
While it's true a lot of ceiling fan remotes and receivers are universal, there are exceptions. Obviously you need a dedicated ceiling fan remote, not something picked up at a local wal-mart that controls t.v.'s and dvr's. I would need to know what kind of system you have. One of the most common types is a UC7067 4 dipswitch (64 -bit) sytem. Look in the battery compartment of your remote for 4 tiny micro switches this will let you know. If you have this system, you can get replacement parts from www.fanmanlighting.com or call them at 1-866-600-3267
Oct 15, 2009 | Universal Remote Control Hampton Bay...
I have 21 ceiling fans in my house.
Three suggestions (maybe not viable solutions):
1. Consider creating ceiling fan "groups". A group is a set of fans that is controlled by one remote.
Group: All (or some) in all vaulted ceilings.
Group: All hallways
Group: Outdoor celing fans
2.
Power OFF ceiling fans at the wall switch that are not used often. Those can have duplicate codes.
3.
If the remote controls are iR (infrared) rather than RF (Radio frequency), then the ceiling fans that are farthest apart or have more solid walls in between, can have the same codes and not be affected by the "wrong" remote.
Oct 01, 2009 | Sea Gull Lighting 1555-734 Three-Light...
How do you set the switch for 3 adjacent ceiling fans
Each remote/fan unit has to be set to a different code otherwise you will always have this problem. Open up one of the remotes and you will see the area where the numbers can be selected, usually one thru five. Then remove the cover on the fan at the ceiling and you will see the same set up. Just go from unit to unit and do not use the same code on any two fan/remote sets and your problem is solved.
Jul 31, 2009 | Hunter Ceiling Fan Light Remote Control
I bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Need code for remote to ceiling fan
There is no set code from the factory; usually all the dip switches are in the same direction. In order to find the code, you will have to take the fan down, pull the remote out far enough to observe the dip switches, and then set them the same way on the remote.
May 19, 2009 | Hampton Bay 13087 70450 Carousel II...
Hunter ceiling fan remote control will not work
Are you talking about just activating the fan, or the tv as well? If you just need the fan, in the top plate where your fan is mounted into the ceiling, there is a box. This box has 4 switches that are turned on or off towards a number. You find that and then just open your remote up and set the switches in the remote to the identical numbers. I need help for the tv codes i lost the booklet, i need the codes for a daewoo.
Apr 26, 2009 | Hunter 20537 / 20538 The Vista Iron...
Dryers Logo
85 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
