Question about Motorola Walkie Talkie 2-Way Radio
Not recieving voice on FCC ID K7GSX900
RADIOS TAKE CHARGE COME ON FUNCTION CORRECTLY IN EVERY WAY EXCEPT WHEN U KEY THE MIC U DONT RECIEVETHE SIGNAL ON THE OTHER RADIO
    Master:
  • 623 Answers
Be sure the channels and codes are set identically on both radios.
Posted on May 04, 2014
SOURCE: Motorola Talkabout T5400
Hello, There is not compability issue, sounds like you have a mic problem because you hear the Roger Beep and that means that the transmition and Reception cicle is working if you could test an audio accesorie would be great. There is another possibility if one of the radios is out of frequency you could experiment the same symtoms.
Posted on Apr 16, 2007
Benimur
  • 6966 Answers
SOURCE: Push to talk problem
If indeed radio #1 has a mic problem, this may be confirmed by trying an external speaker/microphone plugged into the accessory jack. If still a no, then its not the mic but possibly the modulator circuitry. If there is transmit audio with the external mic and hence internal mic is defective, the unit would have to be pried open and the defective component replaced. The internal mic is normally an electrofet 2-3 terminal soldered to a shielded wire and physically attached to the front plate.
Alternately, another possibility is that radio #2 has its Interference Eliminator Code enabled/activated. This is indicated by the presence of small sized digits on the top right of display. If this is the case and no similar digits are displayed in radio #1, then radio #2 will not allow any received transmission to be heard. Along the same line of reasoning, if the code is activated on both radios signified by the presence of the 2 small digits, and radio #1 has a problem with its CTCSS (code) generator, then it would also prevent reception of radio #2. A way to verify this is by deactivating/disabling the Interference Eliminator Codes on both radios.
On certain occasion, it is also possible that radio #2 has a defective speaker. You should be able to verify this by plugging in an external speaker to the accessory jack of radio #2.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 10, 2007
eradiostore
  • 1654 Answers
SOURCE: Transmit button on the lapel mic will not key the radio
Two things which come to mind, one would be if the PTT on the remote mic is bad/defective, second would be you are plugging the audio device in with the radio turned on.
If your remote mic is failing, the PTT is a repairable item, as is the cord on most models.
Posted on Mar 30, 2009
  • 3289 Answers
SOURCE: I can't get the radios
These are multi-channel FRS / GMRS radios. In order to receive transmitted signals from the other radio, they both must be set to the same Channel and the same Interference Eliminator Code. One without the other will keep audio from being heard on the receiving radio.
I suspect you need to refresh yourself with the radio's controls and settings. If you have lost the manual, you can get a copy free of charge from Motorola You'll need a free program called Adobe Reader to view it.
Once you have everything - look at the right hand side of page 1 for "Talking and Listening" followed by "Menu Options" to set the radios up correctly. Keep in mind that if VOX is selected, and there is sound near both radios, they both will transmit at the same time - since the radios receive OR transmit at any given time, no audio will be heard from either.
Please rate this reply if helpful & good luck!
Posted on Aug 18, 2010
eradiostore
  • 1654 Answers
SOURCE: lost manual to my daughters
Here is a link to the user guide we think you are needing: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
Posted on Sep 13, 2010
How do you make motorola FCC ID:K7GSX900 rang longer.
you do not as they have set range non adjustable .
Mar 13, 2016 | Motorola Cell Phones
I need instructions on a Motorola walkie talkie FCCID K7GSX900
Go to the following web page and download the manual: http://www.manualdisk.com/pdf-/motorola-walkie-talkie-fcc-id-k7gsx900-range/
Mar 04, 2015 | Motorola Radio Communications
Recieve voice on k7gsx900 radio
Make sure they are on the same channel
Oct 19, 2014 | Radio Communications
I have 2 cobras 29 radio always worked good till recently. Have a rk56 mic I can hear but can't talk. Mic keys up but they hear nothing bought a new 29 chrome digital read out and a new mic just a wood...
If you are saying that you put out a signal but they can't hear your voice, the battery in your microphone is dead or the 9 volt battery clip that plugs onto the battery may be broken. Try the battery first since a new battery should make the light come on and your voice to modulate your signal so people can hear you. :-) Mr. 44
Aug 26, 2014 | Radio Communications
NOT WORKING 2 WAYS ONE SET SEND AND RECIVE ANOTHER ONE ONLY RECIEVE MOTOROLA WALKIE TALKIE fcc id k7GSX900 UPDATE
Check your programming. It is possible one of them has a different PL (aka code or interference eliminator code) than the others. Here is a link to the user guide page where you can select your model from the pulldown. http://shop.giantintl.com/Manuals.asp Look at the section about programming and turn off any special features, taking your radio back to a very basic mode, matching all setting between the radios. This should make your radios communication easily together. If not, you may have one bad radio in the mix.
Best regards.
Apr 02, 2014 | Motorola Walkie Talkie 2-Way Radio
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
I hooked up an amp ut when i key the mic no one
Why would you connect an amp up? The unit generates legal power as it is. Use of amps with more than 5 Watt inout is illegal. In addition the equipment has to be type approved by the FCC.
If the FCC catches you, they will confiscate ALL your equipment and levy a fine.
If you want better signals, improve your antenna... it is less expensive AND the improvemnet ALSO happens for the received signals as well !!!
Nov 14, 2009 | Cobra 29 LTD CB Radio
President HR-2510 will not transmit or recieve
Hi Darrel,
Since you didn't say if you have ever used this radio successfully before, I have to assume it is "new to you" and that you have never seen it work or used one like it before. Start with a few basic settings below:
Turn Squelch to minimum.
Set RF Gain (if present) to maximum
Set Mode to AM or FM
Set volume to 1/3 up
Connect to 50 ohm dummy load.
Turn power on. Hopefully you hear static. If not, try SSB or FM. Still nothing? Try connecting to an external speaker.
Chnage back to AM or FM mode. Key mic check & for transmit indicator. If none, change mic or manually short the PTT contacts in the mic or at the radio to see if it can be made to xmit.
If no xmit - insert SWR meter between xmitter and dummy load. Try to xmit on AM or FM again while watching SWR forward power, if none indicated, xmitter is probably defective.
Replacing parts in a xmitter is not recommended. You'll need an FCC license and a fair amount of expensive test equipment to test repairs, set power levels and deviation and perform an alignment to be sure you aren't causing interference on other frequencies and bands.
You'd be better off bringing it to a radio repair shop for repairs and an alignment.
Sep 29, 2009 | Uniden Radio Communications
VHF radio inop
yes try going to raidio shack and asking if they could fix it
Dec 13, 2008 | Humminbird Radio Communications
Looking for a schematic so i can trace the power
GO TO THE FCC WEBSITE:
https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm?calledFromFrame=N
ENTER THE FCC ID # YOU MUST ENTER IT CORRECTLY.
FOR INSTANCE...MY FCC ID # IS G9H3-5810 ENTERD CORRECTLY WOULD BE ON THE FIRST LINE
G9H AND THE NEXT LINE 3-5810.
TRY THIS FIRST UNTIL YOU GET USE TO IT AN IT WILL BRING UP ANOTHER MENU. UNDER DISPLAY EXHIBIT CLICK ON DETAIL
THEIR YOU WILL SEE BLOC DIAGRAMS,SCHEMATICS ETC. HOWEVER NOT EVERY RADIO WILL DISPLAY THIS,IF THE COMPANY PAYS EXTRA $ TO THE FCC CERTIAN THINGS WILL NOT BE DISPLAYED LIKE SCHEMATICS.
THERE IS A WAY AROUND THIS ALSO, THE US PATENT OFFICE. TYPE IN THE PANTENT NUMBER AND EVERYTHING WILL BE DISPLAYED, IF YOU CAN FIND THE PATENT ID #.
HOPED THIS HELPED
KEVIN
Dec 09, 2007 | Cobra FRS 307 (14 Channels) 2-Way Radio
Radio Communications Logo
1,196 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
