Question about Dishwashers
Height for dishwasher is only 33.5 inches
It appears dishwashers are now 34 inches tall. Ideas?
We found a fridgidare dishwasher the had a range of 32.5-34 model number FDB2410HIC1 try it, it saved us from having to do alot of tile cutting
Posted on Nov 21, 2009
There are several dishwashers from Frigidaire and Maytag that are available in 33-1/2" cutout heights. Best Buy's website now lets you narrow your search by cut-out height, which is very useful for this search.
Posted on Jun 19, 2010
  • 82 Answers
May be able too remove or lower adjustable legs
Posted on Jan 05, 2009
Which dishwashers are less than 830mm high, to fit under my work surface?
Peter,
830mm equals 32.68 inches. You will just have to look at the specs of any dishwasher that you are interested in and see if they will fit in less than that height. Most dishwashers that I have installed would fit between 32 and 34 inches in height. Hope this helps!
May 15, 2015 | Dishwashers
Avanti calls for a cabinet height of 34 1/2". However, the dishwasher is only 32 1/4" tall. What do you do to fill the gap of 2 inches at the top?
you don't fill the gap. There needs to be some clearance for the door to be able to swing open without contacting the underside of the counters. You can always decrease the gap a little by using the adjustable stands on the bottom of the unit. The unit will come with a kickplate that can adjust to multiple heights.
Apr 27, 2015 | Avanti Dishwashers
What are the dimensions on a Kenmore 363.14192992 dishwasher?
Dishwashers that are installed into standard kitchen cabinets have a standard width and depth of 60 cm (Europe) or 24 inches (US), and most dishwashers must be installed into a hole a minimum of 86 cm (Europe) or 34 inches (US) tall. Portable dishwashers exist in 45 and 60 cm (Europe) 18 and 24 inch (US) widths, with casters and attached countertops. Dishwashers may come in standard or tall tub designs; standard tub dishwashers have a service kickplate beneath the dishwasher door that allows for simpler maintenance and installation, but tall tub dishwashers have approximately 20% more capacity and better sound dampening from having a continuous front door.
Feb 06, 2015 | Kenmore Dishwashers
I only have 33" for undercounter dishwasher is there one
most will fit in there 33 inches is normal height for a counter
Aug 20, 2014 | Whirlpool Dishwashers
My dishwasher was installed, then wood floors added and now the height is only 33 inches. How do I get the old one out and find a new dishwasher that is 33-33 1/4 inches tall?
Take a sawzall and cut the front legs, pull the dishwasher out until the back legs hit the new wood floor and then cut those legs from the sides. It's your old dishwasher anyway, so who cares if the legs are cut off?
Aug 13, 2011 | Dishwashers
What are the product dimensions
Hi and welcome to FixYa, I am Kelly. The installation guide with the dimensions can be found here:
http://www.managemylife.com/mmh/installation_guides/3932/KENMORE-Dishwasher-L0504234?brand_name_search=665.15952 (7.87 mb file)
The top of the cut out is 33 & 7/8" Min. to 34 & 7/8" Max (adjustable legs for height)
Minimum space to counter top parent material 1/4" (Top of dishwasher cabinet is screwed in at the top)
Depth 24 & 1/4 inch minimum
Width 24 & 1/4 inch minimum (Allows for 1/8" clearance on both sides)
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Kenmore 15952 Dishwasher
I need the depth of the dishwasher I have the height at 34 1/2 and width at 23 7/8 Maytag MDBH969AWW
This may be too late for your needs, but, the assembled depth is 26 inches. 49.5 inches with the door open.
Jun 20, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
Need to replace this unit ASAP and am having issue finding one that will fit. My R.O. is exactly 34". The existing unit shown was OK because of the 33 - 1/2. Recommendations?
all dish wahers are the same height
the differance your seeing is that
is has been adjusted to fit your cabinet height
with the adjustable legs
all units can be raised by srewing down the legs
and back levelers
make sure when you do your cabinet measurements you take this into account
Oct 26, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
Dishwasher for 32 inch cabinets
Miele makes a G600 series that are 32 1/4 " tall - that would probably be your best bet.
Jan 05, 2009 | Dishwashers
Whirlpool DU1055xtss doesn't fit cavity where old Whirlpool dishwasher exists
best bet go see your local KNOWLABLE sales rep. generally the mom and pop better then the big chains for knowing what will and wont fit your height requirements
Feb 29, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
4,395 people viewed this question
Top Dishwashers Experts
