Question about Haier HLP140E Electric Portable Dryer
Belt diagram hlp140e - Haier HLP140E Electric Portable Dryer
Can someone show me a diagram of how to install the drum belt for haier hlp140e? I need to know proper route
home appliance repairs should be performed by a qualified service technician. unplug the dryer open the door, remove the filter. there should be a 10mm nut behind the filter. remove the cover on the rear of the dryer.remove the phillips #2 screws. remove the four plate screw, remove the plate from the drum then reassemble.
Apr 23, 2017 | Haier Dryers
Where can I view a video showing how to replace the black belt?
Go to www.repairclinic.com and enter Haier HLP140E to see an illustrated list of common replacement parts and perhaps view a general video showing repair.
Feb 24, 2016 | Haier HLP140E Electric Portable Dryer
HOW DO I PUT DRUM BELT ON A PORTABLE HAIER DRYER I HAVE ORDERED THE BELT IT CALLS FOR FROM HAIER COMPANY TWICE AND IT IS STILL TOO LONG MAYBE I AM PUTTING IT ON WRONG help please
Your idler pulley will take up the slack in it. It won't be real tight any way once on. If there is still a lot of slack when ou turn it on and the drum doesn't turn, then take it back. Take the old belt with you so that it can be matched uproperly.
Jan 25, 2015 | Haier HLP140E 115 volt portable dryer...
PUTTING FAN BELT ON THE HLP140E DRYER
Remove the lint trap. And bolt behind it. You can then move drum or lift out to get ar screws on crossbar
Apr 15, 2014 | Haier HLP140E Electric Portable Dryer
I have a hlp140e and there is a red belt in it that broke, i want to know where i can find a replacement part, or what the part number is.
I found the red belt online at APWagner.com
The replacement part is WP-0350-37
You may also want to order the piece of felt that this belt lays on in the back so it doesn't rub against the drum. The felt is WD-2780-04 and I also ordered this at APWagner.com
Nov 01, 2010 | Haier HLP140E Electric Portable Dryer
Haier HLP140E Electric Portable Dryer Logo
119 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Haier Dryer Expert? Answer questions, earn points and help others
