SOURCE: how to reset MEP counter
You can get the unfreeze code, MEP code, NCK code and SPCK code from third party. After unfreeze your phone, you have to enter the NCK code to unlock and use it with any gsm network in the world. i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website
SOURCE: I need to reset the
For setting the MEP code counter to reset, you can set it on grand reset. This can be done by a good mobile shop. After that you can again get 10 attempts to unlock your Blackberry 9550. Then you can buy the unlocking code with cheaper but reliable rates from an online vendor, for example, Blackberry unlocking codes with IMEI. Good luck and have a nice day.
SOURCE: I need to reset MEP
You can reset your Mep counter by cable method. after that your blackberry 9700 unlock and you can use any gsm sim card in your blackberry bold. this is only the way you can reset .
SOURCE: how to reset MEP counter?
If your Mep attemp 0. cable process is only the way Unlock Blackberry 9700 . go local mobile repair shop. doing this process. after that your Blackberry is unlock and no need to Mep code for your Blackberry. insert any GSM sim card in your blackberry and use any where in this world. i hope this will help you:)
SOURCE: Please help me to reset
You can unlock your Blackberry after finish 10 attemts by cable process. go local mobile repair shop. after this process your Blackberry Torch Unlock .No need to Mep code for your Blackberry . i hope this will help you:)
