Question about Toshiba TZ43V61 43" Rear Projection Television
Black rectangle across my 46in toshiba screen
Tv is about 8 yrs old no previous problems till the rectangle thing
  • jeffrey66 Jan 05, 2009
    you *&^%% rock my freind!!!!!! the problem is fixed. Thank you very much
  • 837 Answers
Turn off close captioning
Posted on Jan 05, 2009
  • Jay Glendenning
    Jay Glendenning Jan 05, 2009
    push the remote button "cap/text"
Two horizontal lines going across the screen
hi i have the same tv mine just started doing this last week were you able to fix the problem if so wht was it
Dec 02, 2012 | Samsung PN50B550T2FXZA PN50B550 50 Plasma...
Black tv screen with line across
Vertical output IC has failed. It should be replaced. You haven't given the brand name and model number here. I assume that it is a Toshiba TV. If so, Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can gather all details. Sometimes, clicking on the ads by the side and bottom of each post might give you more details.
May 28, 2012 | Toshiba MW27H63 27" TV/VCR/DVD
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
A black rectangle showing in the middle of the screen this appeared suddenly
this sounds like screen burn with rear projection and plasma when a picture is left sitting still on the screen sometimes it will burn in to the screen rendering it useless i left my ps3 paused on my old tv then when i changed to bbc one it still had a faint call of duty pause screen in the back it can vary from things like that to logos to your black rectangle the only way of repair is by replacing the screen all toghether i would advise you to just take the screen off and start using the tv as a projector if you cant find a screen it is only a bit of ribbed plastic but very hard part to find
Feb 16, 2011 | Toshiba 46HX83 46 in. Rear Projection...
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
I have an older (about 10 years old) Toshiba 35
You some how have turned on the closed caption function on your tv, go to the tv's menu under closed caption an dturn it off.
Mar 22, 2010 | Televison & Video
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Black rectangle on picture Toshiba CF27H40
Hi
maybe your horizontal yoke is defective..
Thanks!
Feb 25, 2009 | Toshiba CF27H40 27" TV
Toshiba TZ43V61 43" Rear Projection Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
