Question about Nokia N73 Cellular Phone
Memory lock code - Nokia N73 Cellular Phone
  • Nokia Master
  • 14,641 Answers
Delete some unnecessary files in your phone memory like images and videos. Go to your phone gallery and delete some of those. And if you want to use the memory card as phone message storage then go to Messaging - Option - Settings - Other and then Memory in Use, select your memory card.
But if your phone is infected with a virus then you need to format your phone. One sign of infection is your phone keep sending a message randomly from your contacts without your consent.
Use these code and enter it to format your phone:
*#7370# and then the default code is 12345
Take note: Make sure you back-up your contacts or any other important inside your phone.
Hope I make it clear and does makes sense
Posted on Nov 06, 2012
Displaying not enough memory un neccessary
Please delete some phone memory & as well as memory card data. Batter take a backup & then delete.
Aug 21, 2010 | Nokia N73 Cellular Phone
Formatting code for Phone Memory
trensfer all phone memory to Memory card and then try receive data this should work.
Jul 24, 2009 | Nokia 3230
How do you reprogram the keyless door lock code?
  1. Enter the five digit permanent entry code into keyless entry keypad.
  2. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code. (Factory code found on the module).
  3. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code: 9/0-- no memory recall
      1/2-- memory seat position 1
      314-- memory seat position 2
      5/6-- memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
The Keyless Entry Module is located inside the drivers side door.
Jun 21, 2009 | 1985 Lincoln Town Car
LOCK CODE PROBLEM.
Unless you've changed it, it is usually the last four digits of your phone number by default
Mar 30, 2009 | Nokia N76 Cellular Phone
Locking with security code
You need 1 mobile phones and a memory card reader.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card from the locked phone and put it into a
memory card reader. Create
the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to 12345
Feb 10, 2009 | Nokia 5200 Cellular Phone
Nokia E90 forgotten lock code
Option No. 1 is
*#7370# is the code to reset everything, including contacts, sms, emails, all application, everything. But you need the 5 digit security code to do this.
Option No. 2
Since you have forgot the lock code, you can try this thing. Using PC Suit, take backup of your phone contents, then update the phone software.
Option No. 3
Unlock Security Code using Memory Card
Steps to unlock ur sec code.
1. Off Ur mobile.
2. remove battry
3. remove memory card
4. On ur computer and plug in ur memory card.
5. insert ur memory card.
6. unzip the attachment file and place it to ur memory card
e:\system\recog
7. now insert ur memory card into ur mobile and switch on the fone.
8. now if it ask for code type 12345 and ur mobile unlocks.
9. Every times u restart ur mobile it will unlock ur mobiles security code.
Dec 15, 2008 | Nokia N70 Cellular Phone
How will i have a code on my n70?
well, you can choose to use a 'PIN code' or a 'Lock code' or 'Memory card lock'
1. PIN code actually locks up your SIM card, so anywhere you put your SIM card, the message on your SIM card will not be read by anybody without knowing your password. It'll ask you password each time you switch on your phone, but after switched on, it'll not be locked anymore, so anyone can read your phone after switched on.
2.while Lock code, locks your mobile phone like 'keypad lock', the different is, instead of just pressing , left softkey and * button, you need to put password on it (it lock after certain idle time - or you can choose to lock it anytime you want by pressing the on-off switch one time (don;t press too long) and choose the belowest which said lock phone ). this type of lock is commonly used.
3.Memory card lock, locks any application which access your memory card, such as images, text, songs, data that is stored on your memory card. but this type of lock, often bring troubles when the memory card get corrupted. so I suggest number 2 type of lock (lock code)
WARNING!!! all password should be remembered, as if you forgot those password, no body can help you unless technician.. see those articles which people post when they forget their password, so you know the risk and the consequences. But they're actually safe as long as you remember ^^
Good luck, all the best!!
Nov 16, 2008 | Nokia N70 Cellular Phone
Memory locked but dont know the code.tried new card but still says not enough memory
These are different types of codes.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset.
Phone Security Code:
This locks the handset, as opposed to the sim card. Some phones will accept incoming calls with this lock
enabled, but many require the code to be entered even to answer a call. You can also set some handsets to
only accept a "new" sim if the phone security code is entered.
Which is the one that you want?
Not enough memory means your phone is too full of data IE. Pics, Themes, Contacts, Applications, Games etc...
The phone needs a certain amount of memory to function.
Feb 16, 2008 | Cell Phones
Nokia N73 Cellular Phone Logo
21 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
