Question about Philips 47PFL7403D 47 in. LCD TV
Phillips 47 great pic for the 1st few minutes then starts flashing quickly on and off. Still has sound and when the picture is stable the left side (about 4" wide) is slightly darker than the rest of the screen. Could it be a bulb or dirty input ports? Got it for free so if its cheap to fix that would be awesome.
    Top Expert:
  • Philips Master
  • 14,553 Answers
The reason the set was given away is the boards for this model are rather expensive and unless you have a meter and other equipment you likely will not fix it.
As to the other comment, power supply is possible and caps are also possible, I will give you photo of what the bad caps look like if you can get the set open.
Posted on Nov 06, 2012
    Top Expert:
  • Philips Master
  • 74,377 Answers
The capacitors at the power supply section should be suspected. Contact any service technician.
4 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: screen is dimmed and flashing
It's the #1 plaguing issue with flat panel TVs in all brands. If the red light on the TV is blinking when this happens, It should be an error trouble code.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. The Backlight Board supplies power to the screen in different sections. With a 47" screen, it maybe divided into 10 to 12 sections. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 14, 2009
techman007
  • 1112 Answers
SOURCE: no picture on left side of screen and bad picture on right side.
Hello:
Have the Digital board and logic board replaced. the most common problem will be the logic board assembly. Altho the Digital board can also cause this problem. Try taking off the back and making sure the LVDS Cable is connected tightly to the logic board assembly and the panel, (Scrn), The LVDS Cable will look like a small wire harness with two metal clips on each end make sure it is secure, try disconnecting it and reconnecting it again.
Posted on Jan 13, 2010
  • 6 Answers
SOURCE: phillips lcd 47'' turn
Sounds like an issue with the power board or the wire harnesses from the power board to lcd control boards
Posted on Dec 07, 2010
I have sound but no pic it just a scrambled
It sounds like either the controller is bad or the color wheel or scanning sync encoder is dirty or defective. One thing to try is to reset the controller program by unplugging the TV, wait two minutes, then power it ON. The micro-controller will reload it's program from flash memory (which takes several minutes). When the lights are all OFF, turn the set ON and see if the picture is correct. If you select the menu and the picture of the menu is stable, then the problem may be in the signal coming into the TV. Regards.
Dec 18, 2015 | Mitsubishi WD-73733 73" HDTV
Turn on TV and picture and sound are great for about 60 seconds. Then the picture disappears but sound remains.
I would start with checking the power supply 12vdc output, make sure it is stable with no ripple. If the power supply checks out fine, I would then suspect the main board.
Sep 20, 2012 | Vizio VT470M 47-inch 1080p 120Hz 5ms LCD...
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
Lg 47lh30 when first turned on the picture flashes off and on but still has sound.It does it for a couple of minutes then it goes back to normal.
This problems are those 2 long boards call the LCD inverter boards.There one long LCD inverter board on the left,one long LCD inverter board on the right.These 2 long LCD inverter boards are having problems and the causes.It providing a backlight to the LCD screen panel to get a picture.When ur tv are finally have only a few flashes of picture and died for good have sound only left.Those 2 long LCD inverter boards are the causes.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Dec 01, 2010 | LG 47LH30 47 in. LCD HDTV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Philips 47PFL7403D 47 in. LCD TV Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
