Question about Legacy LDN7U Car Video Player
I wanna know the functions of legacy ldn7u
As rear view camera
I am listening to the radio and its changing from stereo to mono and its driving me crazy is there a way i can set it to stay on stereo or do i deal with that.
Usually that happens if you have poor reception. If it's at home you can install a better antenna or sometimes putting the receiver in a better location will help.
Oct 21, 2014 | Legacy LDN7U 7-Inch Motorized Touch Screen...
My legacy ldn7u always seem to have a motor running sound is this normal
it could be your engine fans too cool of the engine
Jan 14, 2013 | Cars & Trucks
Won't play mp4 files
does your video player support the Mp4 video files?
if it can,you can check the resolution is whether right or wrong.
if it can not,just use a video converter to convert the videos to the right format for it.
Here is the Best video converter i have ever used.
May 10, 2012 | Legacy LDN7U Car Video Player
I need a replacement manual for lost manual for fuji a 370 camera please
http://fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-a370/support
try this page.
Dec 07, 2010 | Fuji Finepix A370 Digital Camera
My pioneer double din screen says ''Caution, screen image may appear reversed''...how can i solve this problem?
As you know, you can use this DVD AV Receiver with a rear view camera. And also it can be installed to switch automatically from the video to rear view image when the gear shift of the car is moved to Reverse position.
But it is important to use a camera which outputs mirror reversed images.
Otherwise the screen image may appear reversed. And this means that you will see the rear view reversed in the monitor. And that may cause accicent and injury.
To solve this problem, first check your rear camera whether it has the capability to output mirror reversed images.
If it is, then check the wire connections of the rear camera using the operation manual or ask a technician.
Also check the settings of camera polarity if it is set properly or not in the system menu when connecting the rear view camera.
You can download the operation manual (pdf file) by clicking here.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | Pioneer AVH-P4000DVD Monitor
I wanna view my call logs
sorry this function not available now...
May 06, 2009 | Cell Phones
Fuji Fine Pix F420
Try going to this site. You should be able to view and download the manual in pdf format here.
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-f410-zoom/support
Jul 31, 2008 | Fuji FinePix F420 Digital Camera
Screen
Sadly the D40X does not have a live view function. You can only view shots you have already taken or use the display to make adjustments to the settings.
Currently the only Olympus digital SLRs have live view.
Mar 23, 2008 | Nikon D40x Digital Camera
Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
OR
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Jango
Dec 11, 2007 | Kenwood DDX7019 6.95 in. Car Monitor
Legacy LDN7U Car Video Player Logo
22 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
xxxxxx xxx
Brandon Berry
Brandon Berry
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
