Question about Whirlpool Dryers
LG5791XSWO BURNER NOT LIGHTING ALL THE TIME, INTERMITTENT
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The symptom you have indicates weak solenoid coils. The gas valve should open and the burner should ignite every time the glow bar igniter glows before it fades back off. Weak solenoid coils will usually open the gas valve until the solenoids become hot from the current and flame and then they don't have enough power to open the gas valve.
Replace both solenoid coils and your dryer will most heat and operate normally again. In order to access and replace the solenoid coils you will need to remove the front panel.
Here is the coil kit to order.
Posted on Nov 06, 2012
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
https://www.youtube.com/watch?v=dP3l5AW3YrI
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ...
homeguides.sfgate.com > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
I have a kenmore gas range md 79072909012 the oven lower burner has delayed ignition to the point that temperature is loss in oven and heavy gas smell in home....I am a licensed mechanical contractor in...
If its lighting with the panel and baffle removed, but now with them installed, but you get a heavy gas smell its likely the gas mixture is too rich (i.e. the covers are too tight, gas pressure pushes all air away from burner so only gas and very little air occupies the space above the burner and its too rich to light, oxygen starved.) Not an issue when the covers are removed, so it lights fine. Try adjusting the burne for less gas an more air, see what happens.
Aug 25, 2014 | Kenmore Kitchen Ranges
I was just wondering my rotisiree burner dosent work .. please help asap! thanks
If it is not igniting and hold the flame and getting red, it could be that the burner is dirty and clogged or the thermocouple that keeps the burner lit has failed.Please keep in mind, when lighting an infrared burner, you must hold the burner control knob in for several minutes. At least until all the ceramic plaques are glowing brightly. if the igniter won't light it, try match lighting it, while you hold the burner control knob in.
Most gill manufacturers recommend lighting and burning the infrared rotisserie burner on a regular basis, whether you use it or not,. Doing this helps to keep the burner clean.
I hope this has helped you and thanks for choosing FixYa.
Sep 14, 2011 | Grilling
William forshaire 435 runs well for awhile until
Try cleaning your thermocouple,and resetting it where was, which is located at the pilot flame. this should solve your problem.
Feb 23, 2010 | Heating & Cooling
Oven takes forever to pre-heat and then doesn't keep the temp constant. turning on stove burner helps sometimes, and sometimes it works fine. do we need new thermostat or...? not sure if i have right...
Very common problem, I would replace the oven ignitor first as they get weak with time and cause intermittent burner lighting. Good Luck, Appliance Specialists
Dec 31, 2009 | Maytag MGR5750 Gas Kitchen Range
When lighting any burner...the igniter continues after lighting."click, click, click, click, click" and so fourth. Thank you for your time.
My parts list doesn't tell me if that is an auto relight unit or not. But since you say it happens on any burner I'll leave out stuck ignitor switch for now.
Check the house ground wire to the unit and check that the burner caps are installed properly. The auto units read a ground when they ignite so if the burner caps are on wrong or dirty they can cause this.
jim
Jul 27, 2009 | GE 30 in. JGP326 Gas Cooktop
HSI ignitor is glowing red but furnace isn't lighting every time
most likely the gas vavle only buy honeywell valve the rest are junk
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
Gas dryer not heating
Try new gas valve coil packs they are inexpensive, and easy to install and fix 90% of intermittent lighting complaints
Oct 15, 2007 | Dryers
Dryers Logo
375 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
