Question about Samsung Televison & Video
Power flashing on/off when plugged in
Samsung tv, i believe 46", flat screen, model number LNT4066FX/XAA, Version SS04. When i plug the tv in the power and red light on the front just flash on and off until i unplug it again. screen does not come on and Im a Toyota tech and pretty tech savvy so i shouldn't have a problem fixing it, if i could just figure out what the problem part is. any help would be great. thanks in advance.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
General info first and then some photos---
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo.
power flashing on/off when plugged in - 11_6_2012_2_56_25_pm.jpg11_6_2012_2_56_54_pm.jpg
The standby runs 7/24 and to save money they use caps close to the actual voltage---not too smart but saves money when making and the get hot and dry out inside---hence the puff which is really nice as if have that 95% of the time if replace the caps (slightly higher working voltage please) you have a working set.
Posted on Nov 06, 2012
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
skotkolr
  • 558 Answers
SOURCE: funai 32 inch plasma tv
bad components on the power board needs to have service tech look into blown capacitors or transformer on the power board inside the tv.
Posted on May 28, 2008
  • 3 Answers
SOURCE: flashing red light
Your power supply is faulty I'm afraid. Unless you have soldering skills, I am afraid you will need to contact a professional TV repair person. If you feel confident to try the repair, contact me with the model number, and I will let you know what components you need to change
Posted on Mar 06, 2009
SOURCE: Lamp problem or else?
You need to get the ballast repair kit #LSUC0002 and replace the parts to your ballast.
I have the exact same TV, did the above this past weekend, and the TV works like new.
You need to know how to solder though. It's not that hard.
Posted on Jul 14, 2009
Samsung LCD tv no picture, but OSD/MENU works & when I change channels with cable box, the channel logos display momentarily. Backlights are on. Tried a factory rest. Tried service menu EEPROM reset.
Check the T-con board and the power supply to see if one or more voltages are missing. You may have to download the contents of the eeprom and flash it
Aug 13, 2016 | Samsung Televison & Video
When plugged in TV lights up but has no picture or sound.
BN81-01286A is the part number for the T CON board on the SAMSUNG LNS4692DX/XAA. I just ordered one about 3 hours ago on Ebay http://www.ebay.com/sch/i.html?_trksid=p2047675.m570.l1313&_nkw=SAMSUNG+BOARD+BN81-01286A+A%2FS-T+CON+BP8101286A&_sacat=0&_from=R40
Oct 16, 2012 | Samsung LN-S4692D 46 in. LCD HDTV
Flashing screen on lcd tv
Not sure if this model is one but a number of Samsung's have this issue and a lot of them a jumper needs to be removed on the power supply board---most likely voltage inside the power supply is pulsing
Aug 27, 2012 | Samsung LN-R460D 46 in. LCD Television
Samsung LCD model # LNT4066FX/XAA when I turn my TV on nothing happens except it starts clicking on & off & keeps doing this until I unplug it. sometimes it will get lines on the screen after it...
You have swollen caps on your power supply. Unplug the set and take the back off. You will see them right away. On the power supply board you will see them with bulging caps. They should be flat like the other caps. Replace them with the same value caps and you will be back to normal.
Jul 18, 2011 | Samsung Televison & Video
Our Samsung TV model HLT6187SAX\XAA is displaying a message on screen "Check fan # 2" Red and green lights on the lower right front are flashing. What does this mean?
There is a bad fan in your T.V. You would have to open it, see which fan isn't spinning, get the part number for the fan, order it and replace it.
Jun 19, 2011 | Samsung Televison & Video
I have a samsung flat screen model # LNT4665FX/XAA that is about three years old, when I turn it on it clicks about 6 times before coming on. What could be the issue? It also seems to flash pixels...
Your TV most likely has faulty capacitors in the power supply section of the TV. This is a failry common problem.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
2c07611.png The number one cause for the symptoms above are faulty capacitors within your Plasma or LCD TV. The number one reason that these parts fail is that TV manufacturers often times use lower grade capacitors in their efforts to reduce costs. After several years these lower grade parts will tend to fail first. To insure that these parts will not fail again its imperative that they are replaced with high temp, high quality, low-ESR caps. You can find the parts online from sources like Digikey or you can get complete reair kits incuding the parts, repair instructions, and support from www.TvRepairKits.com
Dec 15, 2010 | Samsung LN-T4671F 46 in. LCD Television
I recently had my tv repaired for diode problem,it is a samsung LNT4066FX/XAA flat screen.Now instead of clicking sound and not turning on the power bar at bottom stays blue and the picture has color...
Well the capacitor problem usually causes power up problems. If your tv comes on now it sounds like you dont have the same problem.Vertical lines are usually caused by bad flat panel or dirty ribbon cable contacts on flat panel connections.
Aug 19, 2010 | Samsung LNT4066F 40 in. LCD Television
I have a samsung model LNT4066fx ,series S303 its
The slow turn-on is normally a sign of a failing power supply and certain conditions could cause noise in the digital circuits of the set. The clicking is likely a relay that is controlled by PS circuits that are detecting a fault condition and repeatedly disconnecting the AC. The late turn-on will eventually turn into no power on at all.
Apr 04, 2010 | Samsung LNT4066F 40 in. LCD Television
When you turn on the TV it takes about 20 to fully turn on. sometimes we get pink lines on the screen.
CHECK POWER SUPPLY BOARD ...OR REPLACED
POWER BOARD NO:
Samsung BN44-00167A BOARD, POWER (VERISONS SX07,SX05,SS03,SQ01)
Samsung BN44-00165A BOARD, POWER (VERSIONS SX08,SX06,SS04,SQ02)
Dec 31, 2009 | Samsung LN-T4065F Television
Cracked 46 inch screen on my Samsung tv. Where can I get a good deal on replacement? Or can it be repaired? Please help Model number is LS46BHPNB/XAA
You can go to Encompass or J&J electronics for the Panel. But If you have never replaced a Panel before, it is best left up to a trained Samsung tech.
Jul 08, 2009 | Samsung LN46A650 46 in. LCD HDTV
Televison & Video Logo
566 people viewed this question
Henry  Thomas
Henry Thomas
