Question about Toshiba Satellite M35X-S349 Notebook
More Specific Toshiba Satellite M35X-S349 assembly
Just took my notebook apart to clean the fan. I followed all of the instructions on the YouTube video to disassemble it; now, I am having trouble getting it back together. There were no reassemble videos for this model. I now have two long thin wires leading from my LCD, and I do not know where they go, or, even if they connect to anything. Does anyone know how to reassemble this model?
  • Toshiba Master
  • 32,281 Answers
The long thin wires are the aerial wires that connect to the wireless card. they are normally a black and a white wire and they have a connector that attaches to the wireless card.
Posted on Nov 06, 2012
rtrahan
  • 741 Answers
SOURCE: how do i connect my dvd ram drive on my toshiba m35x s114?
Is this an external drive? Here a tip: Anytime you use a peripheral with USB you must load the drivers first, then hook up the device. This is only with USB devices. So try uninstalling your DVD driver, unplug the DVD player, reload the driver for the DVD player, then hook the DVD player back up. That should take care of it.
Posted on Dec 22, 2008
SOURCE: Toshiba mx35 s-111
Check to make sure the cable to the screen is in place. Often when you take these notebooks apart the cables become loose.
Posted on Mar 07, 2009
TampaNative
  • 778 Answers
SOURCE: fan Problem - Toshiba Satellite M35X-S349
Your fan is running to keep your system (mainly your processor) from overheating. Heat is the biggest enemy of laptops, and most aren't designed to put on your lap (as air intake ports are usually on the bottom and blocking them with your pants, comforter, blanket, etc... will not allow air to circulate causing heat sensing hardware/software to kick the fan into high speed) as that name would suggest. I believe that Notebook computer is the more proper term for most of them, though some are designed with no air intakes on the bottom side, unfortunately yours does. When you opened it up and "cleaned it" did you clean the heat sync and the other components or just the fan? If your PC is in a smoking environment it will have tar build up holding the dust and need a more thorough cleaning than just blowing it out with canned air from the outside (you may want to disassemble it and clean it with a non residual, non petroleum based contact cleaner. Otherwise there are plenty of temperature monitoring softwares out that will tell you what the processor and harddrive temperature are and most have free trials that you may want to try to see if heat is your problem. There is also software available to monitor and even increase/decrease your fan speed.
Good Luck.
Posted on Feb 24, 2008
  • 27 Answers
SOURCE: Computer crashes when turn on Wireless switch
problem:sounds like polarity is switched on wireless card
Solution: remove cover plate on bottom and make sure black wire runs to Main and white wire runs to AUX
Posted on Aug 02, 2009
jaye_ellen
  • 591 Answers
SOURCE: how do i connect the dvd ram drive on my toshiba m35x s114 satellite notebook
DVD RAM drives plug in to any available USB port. Your computer should assign it a drive letter; using Computer, explore ther drive's contents looking for an Install application. Run this` application and you ought to be able to get to the drive.
Posted on Sep 23, 2009
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
Toshiba satellite m35x-s114 ( black screen ) , i can hear the fan on start up. is there something i can try to solve the problem.
you need to pull the top of the unit off and unplug the monitor from the main mother bord then plug it back in to re fire it .
Jul 04, 2010 | Toshiba Satellite M35X-S349 Notebook
Satellite M35X-S349 PC Notebook: How do I speed up my toshiba pg 35 laptop...
RegTOOL can helps you scan your PC, safely clean the errors & invalid entries cause system slow, freezing and crashing, and repair registry problems to speedup your computer performances. It is easy to use.
http://www.keep-pc-clean.com/
May 18, 2010 | Toshiba Satellite M35X-S349 Notebook
Suddenly shutting off power sometime beeping
there was a problem with notebook overheating and it would be fixed by cleaning the cooling component ,check the heat sink and the fan. The notebook processor produces a lot of heat when the notebook is turned on you check
If the fan working fine, then check if the heatsink is clogged. In some cases you can clean the heat sink with compressed air,
Thanks,
Dec 23, 2009 | Toshiba Satellite M35X-S349 Notebook
Boot Recovery Wizard
try f1 f2 if that dont work then f10 f11 or f12 it has to be 1 of them
Oct 07, 2009 | Toshiba Satellite M35X-S349 Notebook
Aug 02, 2009 | Toshiba Satellite M35X-S349 Notebook
Need to replace toshiba satellite m35x-s163 fan
Unless you are really comfortable with opening laptops to upgrade parts, I won't recommend doing this. Rather get a notebook cooler. It does the job of cooling the notebook pretty well.
Nov 05, 2008 | Toshiba Satellite M35X-S349 Notebook
Laptop fan
Hi. The common problem with these is dust build up in the heatsink fins, but I would have thought the fans would be runnnig hard. try cleaning the dust out by putting a vaccuum cleaner against the grills and around the fan intakes. apart from that, they can have fan failure when trying to run at idle speeds (they may still work at boot) - especially if the fan(s) were running with a slight rattle previously.
Mark
Oct 25, 2008 | Toshiba Satellite M35X-S349 Notebook
HD isnt running
Sounds like your motherboard just died. This is a known issue with Toshiba. They extended the warranty until Nov 7th of 2007, but now it is out of warranty. :-\ You could try phoning Toshiba (good luck getting someone who speaks English) and see if they have any other solutions. Repair is in the neighbourhood of $500 or less, so it seems.
Dec 04, 2007 | Toshiba Satellite M35X-S349 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
