Question about Electrolux Washing Machines
Doesnt spin good & makes a funny rubbing sound
    Top Expert:
  • Electrolux Master
  • 9,472 Answers
See other post
Posted on Nov 06, 2012
3 Suggested Answers
  • 43 Answers
SOURCE: Spin cylcle not working. Makes a funny sound and does not spin
There is a part called the Wig Wag. It is 2 solenoids on a metal bar about 6 inches long. It has a hole in the center of the bar and 3 electrical wires go up through the center. One is a common wire and the other two go to each selenoid. One selenoide when activated causes the WIG WAG to shift the Transmission into WASH MODE or SPIN MODE. They are powered by 115 VOLTS AC and is enough to KILL YOU.
What you will find is the 3 wires are held together by a few wraps of electrical tape. Because the WIG WAG moves while the machine is running, the wires are all the time FLEXING. Eventually a wire will break and in this case it was the SPIN Wire to the SPIN solenoid.
Replacing all 3 wires is the best fix. Splicing near the wig wag could cause the wires to break again, They could then pinch or touch the moving metal parts and if the washer is NOT properly GROUNDED someone could get ELECTROCUTED and KILLED.
USE CAUTION doing this repair. The replacemet wire needs to be FINE Grain Flexable wire. If you use something like Lamp Cord that is not designed to be flexed hundreds of times will soon break.
Check with Sears Parts and ask for a Wig Wag Wire Harness.
You can lay the machine on it's back and see this problem. Caution plugging it in on it;s back, something could break.
The Wig Wag can take your fingers off..... CAREFUL !!!!
Do this repair at your own risk. It is dangerous.
At least you will know what to tell the Repairman.
Posted on Apr 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: My He2Plus kenmore frontload washer makes a loud
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
My washing machine is a Hotpoint WM75S and is making a really funny sound when it spins, we have had it for around 1-1.1/2 years
It sounds like the spin basket rear support is loose.The support is part of the spin basket & does not come separately. This type of repair will more than likely need the spin basket replaced & possibly the outer tub also. It will cost you $200-300 to replace the assembly.
Hope this helps.
Shane
Mar 10, 2011 | Washing Machines
Hello. Near the end of the spin dry cycle, the drum started to make a loud rubbing sound (12 minutes to go???). We shut down the washer, with a cancel, then restarted the load over again. This time we...
100% if its rubbing instead of freely rotating while you manually spin the drum your bearings have gone,You can't see it's all inclosed in a plastic shell & it is pretty much a complete rebuild pain in the neck job that you are going to recieve quote's of $500 buck's or more to do the job might be worth getting a new machine it would be more economical.GOOD LUCK
Feb 25, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Fridge is getting warm & making a funny sound could it be compressor?
It could be the compressor or the start relay. If you hear a click sound, then your relay is good and your compressor is shot. If you do not hear a clicking sound, then your compressor is good and your relay is shot. Also check to make sure that under operation even if the compressor does not work the fan should still be spinning, even if it is warm air. Please rate
Jun 04, 2010 | Kenmore 57029 Side by Side Refrigerator
Making noise when spinning
HI there.This sounds like the centre bearing & seal are worn causing noise & water leak.It's normally called a Hub & Seal Kit.It is quite an involved job & without the right tools it would probably cost somewhere around $300 upwards to have repaired.Very good quality machine & worth while repairing.Try to avoid useing the machine until repaired as you could cause electrical short due to water leaking.
May 28, 2010 | Speed Queen AWS44NW Top Load Washer
My 18-55mm lens isn't sharpening and makes a funny sound
Try cleaning the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
May 16, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Will not spin and smells funny
Does the washer agitate while in wash cycle? Does it move at all? It may be that the motor that drives the spin and wash cycle is not working. If it smells funny, it usually means that you have bearings gone bad or a belt, if it is belt drive, broken. You can replace these parts. All the parts involved with spinning can be replaced. The parts are available from the maker. It may be a spin clutch, agitator gear, pulley, or a transfer case..
Please leave good ratings, email me if you have more questions
Aug 07, 2009 | Washing Machines
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
LOCK AND LOAD ISSUE
can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Jun 28, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
