Question about Vacuums
Kenmore upright vacuums Model 11635922502 - Vacuums
    Top Expert:
  • Vacuums Master
  • 14,553 Answers
What is the issue or problem?
Posted on Nov 06, 2012
  • 715 Answers
SOURCE: The brush isn't turning on my Kenmore progressive
replace the belt
Posted on Nov 05, 2009
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same problem. The agitator stopped turning after I sucked up a foreign object (my wife's watch) and it got jammed in the intake. After removal of the watch the agitator did not spin when turning on the machine, and the reset button never deployed (it remained buried in its housing and would not depress with a paper clip). The agitator was not bound and I could manually move it in both directions with ease. Faced with prospect of paying $125 or more for a repair, a good sharp kick to the chassis from the top promptly fixed the problem. I have found that kicking malfunctioning electronics often works.
Posted on Dec 05, 2009
SOURCE: my kenmore beltless upright canister vaccuum doesn't spin anymore
Ensure the agitator is not bound up and can be moved manually by hand in both directions. Clean any string or binding material if you find it. Press the reset button on the top of the chassis. If it clicks, then you should try turning it on and see if the agitator spins. If it doesn't spin, I have had luck giving a sharp kick to the top of the chassis.
  • 148 Answers
SOURCE: i need a belt for a kenmore 721 vacuum please
Should be able to get one at local Sears store , or try sears.com
Posted on Feb 13, 2010
SOURCE: kenmore upright vacuum model 116.35923500.
There is a switch that tells the cleaner that the upright is locked upright and the beater bar won't spin until you depress the foot release and tilt the cleaner. This switch mount is poorly designed, its just sitting in a pocket at the pivot of the cleaner. I had to double stick tape it in the pocket to keep it from moving around and put silicone spray on the pivot. The pivot actuates the switch, but its a bad design.
  • Remove front cover, to do this, pull out the bag, remove the screws under the bag and on the outside. 12 screws total.
  • Locate switch on pivot
  • Confirm mounting of switch, re-adjust and use tape or epoxy.
  • Reassemble and test.
  • This is for a Kenmore 35923500 upright direct drive.
Posted on Jun 14, 2010
Same problem as skatemom;brushes wont spin tried reset button model 11635922502
Check that the belt is in position, not slipped or broken. This is what turns the rod with the brushes.
Aug 17, 2011 | Kenmore 31913 Progressive Direct Drive...
Is there an easy way to see if a drive belt may be broken? It's so difficult to push my Kenmore upright vacuum!
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
Feb 15, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Aug 01, 2009 | Kenmore Bagless Upright VacuumVacuum
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore Upright Model 116.356224400. Belt
A picture is worth a thousand words, so the diagrams in this manual should be helpful:
35622 Owner Manual
Jan 19, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Clogged vacuum - Kenmore 35922 Slate Blue
35922 is not the complete model number, it will be on the back or the bottom of the vacuum. Example: 116.35922****
Sep 02, 2008 | Kenmore 31912 Progressive Direct Drive...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
