How to reset Bosch washer connectors and connections
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 06, 2012
  • bduinkerk
    bduinkerk Nov 06, 2012
    My Bosch washer Nextt 500 plus series won't spin. It seems to drain the water ok but clothes are wet.
  • bduinkerk
    bduinkerk Nov 08, 2012
    The drum turns one direction anti clockwise, belt is ok, strainers and drain pump have no obstructions,.I can turn drum all around. Might have to find a technician still don't know what the problem is and dont know how to check the motor brushes. Hoses have no obstructons. No error given on the panel.
I have a Bosch Maxx WFL 1662 washing machine. It does not stop washing and go over to the rinses sickle.Where do i start looking for the problem?
Hi Eric, There's two links below... 1st link is Bosch Washing Machine Error Fault Codes and the 2nd link is worth reading, The master reset is only part of the trouble shooting, I hope these help.
To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 02, 2016 | Bosch Washing Machines
Hoover washer dryer wd 9616c error code e13 and burning smell from the rear????
The automatically suggestted E13 guidance that the system posts referring to Bosch machines is irrelevant I'm afraid. On a Hoover, the message means "Faulty module connections. Check all connections between modules and associated wiring." The chances are that you have a partially dislodged connector on the main board, or on the connector that goes to the motor
Oct 14, 2015 | Hoover Washing Machines
HOW DO I CHECK THE PRESSURE SWITCH ON A BOSCH 800 WASHER
Connect up an ohm meter to the connectors then blow into the tube attached to the switch. The switch should click and the ohm metre should show readings from full deflection to zero. If no movement replace the switch. If switch does not click check tubing for blockages or splits and cracks. Still no click replace it
Nov 01, 2014 | Bosch Nexxt 800 WFMC8401UC
Draining and filling at the same time
Have you checked that the drain hose is not too low?
The hose should be at least 1/2 the height of the appliance to prevent siphoning out. If the waste hose is the right height this will probably be overflow on the pressure switch. These are located inside at the top of the appliance and have a rubber hose coming off them. if a mechanical one (amp tag connectors) they can be blown into to reset, if they are the newer type they can not be blown into to reset.
If working on the appliance please ensure it is unplugged
Apr 07, 2014 | Bosch WFMC 3200 Front Load Washer
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
Apr 03, 2014 | Bosch Logixx WFT 2806 Front Load...
BOSCH AXXIs - My wash cycle never progresses to rinse and drain.. just stays on wash forever!
It seems that the main controller could be the culprit but this requires you to counter check and confirm the fault before you can proceed to replace. It will be best to check all the connections and reset the pins and connectors. If the cycle goes through well in many modes it is adviceable to use as much by alternating the cycles than to replace the controller if you can manage..
May 31, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Just bought new motor using the motor part number from Bosch. The new motor has a different connector. How am I suppose to connect new motor?
Welcome to FixYa.
Can you possibly provide the model number of your washer as well as the part number of the replacement part.
That way we can speak clear and direct pertaining to your actual machine and part as opposed to generalizing about Bosch this or that.
I will watch for your reply.
Regards,
Macmarkus :)
Sep 23, 2010 | Bosch Washing Machines
Sms68mo2au how to connect electric cord, no seperate cord
The electric connection for most dish washers is a small metal cube in the lower right of the bottom of the machine , near the front. Remove the kick plate to get access under the machine. A screw holds the cover on the power connection cube.. There is a wire there for the power connection. Connect color for color. You should use a connector on your supply cord to protect the connection when the washer is slid in or out.
Oct 03, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 15, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top Washing Machines Experts
