Changing belt on a maytag washer - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 06, 2012
I have a maytag top load washer the washer will drain but will not spin
Maytag washers have two belts one for turning the pump and the other for making it spin. Sounds like the belt for the spin needs to be replaced. It is something that you can do. Maytag washer belts are quite easy to change. Hope this helpedd. Thank you for using Fix ya.
Jun 26, 2011 | Maytag Washing Machines
I have an 11 year old Maytag model PAV2200AWW. My problem is the clothes are still "very wet" after the spin cycle. I've changed load sizes, water levels and checked all of the hoses. Any...
replace washer belt # 21352320 tilt washer back belt on bottom ...check for glossyness on belt and black residue causing belt to slip... make sure motor and pump pulley moves freely...
Jan 27, 2011 | Maytag Washing Machines
How many belts does this washer carry and where do they go?
Both kinds of maytag washers you can see the belts by tilting the washer back . On REAL maytags are two belts on Crosley built maytags is 1 belt
Dec 07, 2010 | Maytag MAV8557 Top Load Washer
Washer has a burning smell and will not drain
the burning you smell is probably your belt. if you change the belt and it still has this problem then your transmition has failed. This is a very comon problem with maytag washers.
Apr 24, 2010 | Maytag PAV2300 Top Load Washer
Tighten motor belt on maytag washer
you don;t!! you have to change them when there stretched out
Jan 19, 2010 | Washing Machines
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Sep 29, 2009 | Maytag Dryers
The moter stops when my maytag washer changes cycles
motor is most likeley bad no adjustment on belt i change motor on this make 3 .4 times a week
Feb 22, 2009 | Maytag Atlantis MAV6000 Top Load Washer
How do I change the washer belt on a Maytag Washer #LAT2500AAE
I figured out that the belt went on the bottom of the dryer. It was actually very easy to fix once I realized where the belt went. I made the mistake of opening the front cover of the washer first, which is why I did not see where to put the belt. Apparently, if the washer is not level (since I had too much for a load and it caused the washer to pull out from the wall), the belt shook itself loose.
Dec 03, 2008 | Maytag PAV2300 Top Load Washer
How do I take the front cover off a Maytag MAV4755AWW washer to change the belt for spinning the drum?
Although I'm not familiar with that particular model, most Maytag washers have the belts under the washer (no need to remove the front panel) --- just tip the washer back and check to see if the belts are underneath.
Jun 22, 2008 | Maytag Washing Machines
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
