Question about Microsoft LifeCam VX-1000 Webcam
Resolution isn't matching.
The program tells me to change the settings on my xp. I didn't make any changes in the first place and the cam was working fine. So I changed the settings and still the same message. Something about 800 to 600 and a 16 bit recommendation. I'm going in circles.
  • 416 Answers
On the desktop righ click & go to properties. you will see a tab called settings, on this make the slider to 800x600 & on the drop down menu make it 16 bit.
Posted on Jan 05, 2009
Using a TI-84 Plus Silver Edition and the screen just went blank in the middle of a class. changed the batteries, didn't help. cleaned the connectors, didn't help. tried to change the resoluti
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
What do you mean by "changed the resolution"?
Nov 15, 2012 | Texas Instruments TI-84 Plus Silver...
I want my monitor to work once again because it says cannot display video mode? i dont understand help me?
You didn't say which OS you're running. However, it looks like you need to restart your computer in safe mode. This URL explains how to get in safe mode. When the computer boots the video it will look a bit grainy and you won't be able to see the entire desktop without using the scroll bars.
Both XP and Vista don't allow you to perform such an operation through the regular procedure and, as a result, you will only be able to get a screen resolution of 800×600 with the consequence that some icons and programs won't be displayed correctly. This is because Safe Mode just loads only basic services and drivers which are strictly necessary for Windows to run.
Fortunately, by employing the following techniques, you can get around this restriction permitting you to get whatever screen resolution you want.
Windows XP:
  1. Right click on your desktop.
  2. Click Properties.
  3. Click the Settings tab.
  4. Under Screen Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced.
  6. On the new window click OK, without modifying anything.
  7. Done, you should have successfully changed the resolution settings.
Windows Vista:
  2. Click Personalize.
  3. Click Display Settings.
  4. Under Resolution, drag the pointer to the right (where higher resolutions are located).
  5. Click Advanced Settings.
  7. Done, you should have successfully change the resolution settings.
Aug 11, 2011 | Dell 1503FP 15" LCD Monitor
How do you change fontz size on dell computer
  1. Change your screen resolution.
    • 1 Right click on the desktop and choose "Properties" (XP) or "Personalize" (Vista.).
    • 2 In XP click on the "Settings tab, and in Vista click on "Display Settings."
    • 3 Adjust the resolution slider to the right or left (right will set a higher resolution, left lower resolution) and then click "Apply." The screen will change to the new resolution.
    • 4 Click "Yes" to accept the changes.
    Alter the text size in the program you are running.
    • 1 Alter the text size in the program you are running. Many programs have their own font-size settings that can often be altered in a view, settings or options menu.
    • 2 Look for an option to change font size or zoom. Often you can click on a "View" menu and then click "Zoom."
    • 3 Zoom to the required size. (For many programs, you can hold down the "control" key and then use the mouse wheel to automatically zoom in and out.)
    Alter your computer's DPI scale setting in Vista.
    • 1 Right click your desktop.
    • 2 Select "Personalize" then "Adjust font size (DPI)," then "Custom DPI."
    • 3 Enter a number between 100% and 500% (higher numbers mean larger text).
    • 4 Click"OK."
    • 5 Click "Apply."
    • 6 Restart your computer.
    Alter your computer's DPI scale setting in XP.
    • 2 Select "Properties," "Settings," "Advanced."
    • 3 Click on the DPI setting you want to use in the drop-down list or select "Custom DPI Setting (other)" and enter your own number.
    • 4 Click "Apply" and restart your computer.
Jul 09, 2011 | Dell Inspiron 530s Desktop Computer
How do I get the websites to fit screen instead of having to scroll back and forth
Change your resolution until you get the one that works for you. You probably need to go to a lower resolution. Right click on an empty space on the desktop and then left click on properties in XP. On Vista right click and choose personalize, then Display Settings. In XP click on the Settings tab and change the resolution with the slider. Click Apply when you have what you want. In Vista match your monitor with the one displayed and then change the settings.
Nov 26, 2009 | Dell E173FP 17" LCD Monitor
I use Microsoft XP and I use a 24" Samsung widescreen monitor. Is there any way I can get my programs to fill the screen without stretching and distorting. I have a friend who has a Dell widescreen...
Its probably your screen resolution, you probably want it set to something with a 16:9 or 16:10 ratio so 1280x768 or 1280x960 or if you are like me and like lots of real estate 1920x1200
Sep 09, 2009 | Computers & Internet
I Have a resolution problem
Did you download the video driver from the Acer WEB site?
The ATI Radeon driver must match the XP or Vista version of Windows that is installed on your ACER.
Jul 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
No full picture
reset the settings to factory default. make sure the resolution matches on both the computer and the projector.
Oct 08, 2008 | Office Equipment & Supplies
Veo stingray webcam
This fix will work for all of the VEO Stingray problems because it gives a good driver download site and it tells you step by step how to get your cam to work with VISTA Good Luck and let me know if this fixed your problems.
1.Go to this site and download the driver you need: http://www.softsci.com/veodrivers.htm
2.Download it to your desktop
3. Don't unzip, install, or plug in your cam yet
4.Search for this in your start menu: Program Compatibility Wizard
5. Of the three choices click the one that says look for the program manually
6. Choose the option for XP
7. Choose the 680 x 420 or whatever it is not the 256 colors
8. Choose to run as administrator
9. Click next and it should change your screen to a real big resolution and then it will start to install the driver
10. Go through the install wizard
11. After it has loaded plug in your camera
12. Try a program that it is supposed to work with
13. Finish the Compatibility Wizard
now everything should work for your cam.
This works with all of your programs that vista will not run.
Dec 26, 2007 | Veo Stingray
Where is the number so i can call u ppl?
Dec 20, 2007 | Veo Stingray
Screen resolution resets to 800x600 after every reboot when d/port is connected.
You may have to set the monitors resolution to match the pc as they may be different.
Jan 13, 2007 | Dell Latitude D620 Notebook
Microsoft LifeCam VX-1000 Webcam Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
