Question about Mr. Coffee FTXSS23GTF Coffee Maker
Leak! At first I started to notice a little bit of water around the base of the unit and thought I was just careless, but now I can lose 1-2 cups of water from a 8 cup pot. I propped up the base to see that there is a drip leak trough one of the slots under the burner. I asssume there is a leak in the water tank. Is there a way to get to the bottom of the tank or fix this some other way?
  • 19 Answers
The plastic tubes inside coffee makers will crack or split over time, especially in models like Mr. Coffee DWX20, causing a leak or pool of water under the maker while brewing. The tubes are fairly easy to access and replace, but PVC plastic tubing from the local hardware store will not do the job. You need food & medical grade silicon tube with a high temperature rating of around 500 deg F = 250 deg C. One-foot lengths can be bought inexpensively on EBay. I installed this replacement tubing in my home and work coffee makers many years ago and have not had a leak problem since.
REPLACEMENT PROCEDURE
Unplug the power cord to the coffee maker and turn it upside down. Remove the retaining screws and take off the base. You should see one or two tubes held in place with wire hose clips, probably blackened at the ends with age.
Use pliers to ease the clips off the tubes and on to the metal pipe ends to which they are attached. Pry the tubes off the pipes with a flat screwdriver. They may be stuck on, so you may have to slice into the tube ends lengthwise with an exacto knife blade. If so, be careful not to damage the metal pipe below. Cut the tube in half where it is in good condition and measure the inside diameter.
The thickness of the new tube wall needs only to be 1/16 inch, so if the old tube was 3/8 inch inside diameter, buy silicon tube that matches it and with an outside diameter of 1/2 inch.
Cut the tube to the correct length to replace the old one, massage it on to the metal pipe ends, and ease the metal clips back into place. Replace the coffee maker base.
Your coffee maker might bubble and sing slightly louder than before while brewing, but that is because it is happy with its new tubing which is probably a thinner wall, higher quality, and more flexible than the original.
Posted on Dec 17, 2013
Why even mess around with a leaky coffee pot? Just buy a new one theres a ton of garage sales if a new one is not in your budget. I noticed the same thing a little leak and as soon as it would start to brew....I also thought I was just spilling water around the heat plate. After a few weeks of wiping the heat plate I decided to invest in something enjoyable.
Bye Nicole
Posted on Jul 27, 2008
2cup rice with 4 cup water. Why is the water boiling out of the cooker?
Way too much water! Use the same amount of white rice to water and a third of a cup more when using brown rice.
Mar 16, 2015 | Farberware Kitchen Appliances - Others
Hi i have vauxhall corsa 1.2sxi twinport 2005, i recently had a mechanic run some tests because it was losing power there was little bit of cream round the oil cap, he did compression test and emissions...
Sometime it is hard to diagnotic head gasket when leak is very small, Put pressure on 15pound air pressure in cooling system when cold and check leak.
You could find it with exhaust gaz analyser in the radiator cap(exhaust leak from head gasket) if so try BARS leak or head gasket sealer in radiator sometime it work for small leak
Dec 06, 2014 | 2005 Opel Corsa
Water builds up on top of k cup and leaks all over the k cup
I had several issues. Initially it would heat up and flash indicating it was ready to brew, but it wouldn't produce any water. It would hum for a while then eventually stop. So, first I used a paper clip to make sure the three holes around the needle that pierces the top of the k-cup were clean.You can also easily remove the k-cup holder and clean the hole for the pin that pierces the bottom of the k-cup. For some people this seems to be enough. That didn't work for me, so next I took the top off to expose the pump tubing (pull top handle all the way back and remove two screws under the top--the screws are a bit hard to get in later, try taping screw to screwdriver so you don't lose screw). I noticed the internal water tank was full almost to the top, so I knew it was not at this point an issue with the external water tank. Apparently when the pump dries out it sometimes can't prime itself, or crud gets in the line. One person said they used a turkey baster to force water up the needle (without needing to remove the top). I'm not sure why that worked, because the pump valve seems to be one way--I couldn't blow air in to it (see below). Anyway, I don't have a turkey baster, so I unscrewed two screws to get at the pump line, and then wedged up the black ring that holds the pump line down to the place of output. I ran the brewer and noticed no water come into the line, so I sucked on it a little bit (like siphoning gas). All of a sudden some very hot plastic-tasting water came through. (Not scalding fortunately.) I ran the brewer again and this time water came out (I just held the now-disconnected line over a coffee cup). I ran it again and this time it was trying to refill itself but no water was entering the brewer. Fortunately, I came across this solution. I re-attached the pump. Then I took off the external tank and Iused a screw driver to push up from the bottom of the valve (underneath where it flows into machine) and saw that water came out freely so I knew there was not blockage there. Next I tried the slam down technique described above. That worked like a charm--the tank started draining and I finally got everything working.
Dec 23, 2013 | Keurig B60 Coffee Maker
Fixed leaking faucet, now handles leak at the base & the water pressure is low
No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
Nov 23, 2011 | Plumbing
Recieved one as a gift lost instructions how much rice to water
Check this procedure:
* Before cooking, rinse rice in warm water until water becomes clear. Then place the rice in the inner pot with fresh water.
* Take care to use proper water to rice ratios.
* Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1 ratio plus ¾ cup of water for brown rice.
TIPS:
# You may wish to tweak the "rice to water ratio" with experience - for example: for larger quantities of rice, you may find a little less or more than one and a half the amount of water results in better rice.
# One cup of dry rice grains cooked in this way is about sufficient to accompany a meal for 2 adults.
# If the rice is a major component of the dish, you might need up to 1 cup of rice per adult.
# Your base measurement doesn't need to be a cup necessarily - the key is to add 1.5x as much water as rice, whatever the quantity.
# It works best to use the original lid of the pot you use, since it will seal best.
# When the rice first boils, it might weep a bit or even lift the lid. Keep watch and an ear out for the start of the boil.
# These times and ratios are for white rice (e.g. Jasmine, Basmati, etc). If you are cooking brown rice you will need around 2C water to 1C rice and double the time.
# Salt is not necessary when cooking rice, but can be added. Unless you add a ridiculous amount of salt it will not significantly change the boiling temperature or time.
# Water boils at a lower temperature at altitude. If you live at a high altitude it will take longer to cook rice using this method.
I hope help with this (remember to rate this answer).
Sep 30, 2010 | Black & Decker RC400 7-Cup Rice Cooker
Cup stuck and will not come out
put a little water around the base of the cup and give it a few minutes. Almost funny. LOL
Jun 30, 2009 | Cuisinart Cup-O-Matic SS-1 Coffee Maker
Keurig maker dispenses too little water when brewing
I found this solution on another post. Unfold a small metal paper clip and insert through the lower piercing needle of the cup holder to **** out any debris in the needle.Even a small piece of coffee or debris can slow the water flow through the cup.
Mar 22, 2009 | Keurig Platinum B70 Coffee Maker
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Quisnart DCC-2000 12 cup (leakage)
If the DCC-2000m is filled past the 12-cup mark, there is a spill gauge at the back that will allow the coffeemaker to keep the cup count exactly at 12 cups.
Dec 11, 2007 | Cuisinart DCC-2000
1 1/2 years old 5 tons leaking yellow rusty water
Most likely yours has a scroll compressor which are notorious for being quite loud on start they will start for years, just a liitle noisy. Is the water from the pvc drain or from the base of the outdoor unit??
Oct 02, 2007 | Carrier 38CKC036 Air Conditioner
Mr. Coffee FTXSS23GTF Coffee Maker Logo
370 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Jim London
Jim London
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
