Question about iLO DVDR05 DVD Recorder
Cd tray will not stay closed it opens as soon as you close it
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, 3 possibilities:
  • tray is not really reaching closed position, belt is loose/worn out (most likely), replacement required;
  • dirt on the laser/optics, false reading, the CD is thinking it has a CD inserted and when it can not read, it ejects. Clean with a CD disc cleaner (likely);
  • virus/malicious software (a possibility), scan/clean.
Good luck and Thank you for using FixYa.
Posted on Jan 05, 2009
3 Suggested Answers
Paeroa
  • 457 Answers
SOURCE: DVD Tray won't stay closed
It can only be repaired by the repair shop I think your son broke a lug on the inside it may need a new tray?
Posted on Sep 13, 2007
  • 4234 Answers
SOURCE: dvd tray will not stay closed. opens and shuts randomly
I'm not familiar with your exact model, but usually when this happens, the loading belt is at fault. There are microswitches inside which determine the limits of the tray movement. There is one that is activated to indicate that the tray is out and another to indicate that the tray is in. If the belt slips, the inner may not be activated and the system will cause the tray to come out. Try replacing the belt.
Keep us posted.
Dan
Posted on May 12, 2009
The cd tray will not stay closed, as soon as unit is turned on the trya comes out the buttons close it but it does not stay closed
most likely your CD player doesn't support the formatting of the CD you are trying to use.
you didn't mention if this happens to ALL the CDs you try to play or only for specific ones.
if you don't use a copied CD do you still have an issue?
Apr 04, 2011 | Rotel Audio Players & Recorders
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Cd door will not stay shut
There might be some problem in ur CD rom motor that control the tray eject,,so u have to take it to nearest service center..
Dec 09, 2008 | IBM ThinkPad R40 2722 Notebook
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
Cd tray on my 360 wont stay shut
either you will need it repaired or u can do it the cheap way and after the disc tray is shut put some tape over it and see if it will read it still. If not it will need to be repaired. It will only cost about $35 or free if you are still under warranty.
Feb 14, 2008 | Microsoft Xbox 360 Console
Loading tray will not load or close-reopens immediately
Sounds like the tray position switch has gone wrong.
Sep 30, 2007 | Onkyo DX-C340 CD Player
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
iLO DVDR05 DVD Recorder Logo
66 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
