Question about Husqvarna Huskylock Computerized 910
Where can I buy the tool to change the needle in the huskylock 910?
  • Husqvarna Master
  • 7,365 Answers
Try a screw driver that you use on eye glasses and see if that will
work.
Posted on Nov 06, 2012
  • 192 Answers
SOURCE: Should I buy a Huskylock or another brand?
Don't buy the machine unless you have a dealer to stand behind it. Anyone can say they have the best. Go to the store and sew on them and get to know the store that you will deal with. See how they treat not only you, but the returning customers who come in while you are there. That tells you about their service after the sale.
By the way, the Babylock is easiest to thread when using conventional thread, but it is very noisy and does not have the ability to adjust individual tensions. If you want to use decorative thread that is heavier than the other threads, you may need to decrease one tension while leaving the others alone. A Babylock won't give you that freedom.
Go to someone who uses their serger regularly for the type of projects that you want to do and ask pros and cons. Then go out and test drive everything on the market. Don't just get a demo, you should be allowed to operate it yourself.
If you aren't allowed to sew on it, maybe you should find another dealer that carries what you want. But make sure to try them all.
Posted on Aug 21, 2009
sewinsnap
  • 135 Answers
SOURCE: remove needle
Yes, a screwdrive that came in the tool kit.
Posted on Jun 24, 2010
Tally Girl
  • 1133 Answers
SOURCE: what tool do you use
Most sergers/overlockers will come with a tool kit including a small flat blade screw driver and a set of tweezers. Both are needed to change a needle along with a steady hand and glasses in my case.
Turn the flywheel towards you until the needle bar is at highest point. If you can, swing the pressure foot out of the way or remove it. Ditto the upper blade, if you can swing it up and out of the way to give yourself plenty of clearance.
Then using your small screwdriver, gently turn the needle screw a half turn at a time until the needle is loose and drops out. NEVER undo the screw all the way out, just enough to get the new needle back in.
Most needle bars will hold two needles with two screws so getting both changed is a bit of a fiddle, I usually slide the new needle up into the slot, then hold it up into the housing with my tweezers while I tighten up the screwdriver. Or I'll hold the tip of the needle up in place using a long fingernail while doing up the screw. YOu may find you need to slightly undo the left needle screw in order to replace the right needle as the two needles sit alongside eachother in the housing very closely.
On most sergers the two needles sit at different heights so have a good look before you remove and then make sure you get the new needle back up into the housing all the way. Always test by winding through a stitch manually just to make sure the needle is clearing your loopers afterwards.
Posted on Aug 03, 2011
SOURCE: I have a huskylock 910 but none of the tools that
check with the sewvacdoctor.com
Posted on Aug 26, 2011
SOURCE: huskylock 910 stuck
since it's a husky lock, it would be a good idea to have the machine serviced
& make sure you have the manual to read so you can get use to the machine
Posted on Jun 11, 2012
Manual for Huskylock 910
are you wanting a instruction manual or service manual?
Aug 25, 2012 | Husqvarna Huskylock Computerized 910
Thread coming out of eye of right needle on huskylock 910
Hi:
Are you sure it's coming out? Or is it breaking at the needle?
Try replacing the right needle and do a test stitch. If it still comes out of the needle... loosen that threads tension a little.
Aug 01, 2012 | Husqvarna Huskylock Computerized 910
Huskylock 910 stuck
Jun 11, 2012 | Husqvarna Huskylock Computerized 910
Huskylock 910 starts to serge normal and then begins to take extra thread and make a mess. what can I do to fix this?
try changing the needles
make sure the serger is threaded correctly
check for any burrs in the needle plate area, or on the loopers
also make sure the tension is adjusted correctly for the fabric
May 15, 2012 | Husqvarna Huskylock Computerized 910
What tool do you use to change the needle on a husqvarna huskylock 910
Aug 02, 2011 | Husqvarna Huskylock Computerized 910
How do I thread the Huskylock 910?
how do you change the needles on the huskylock 910?
Oct 12, 2010 | Husqvarna Huskylock Computerized 910
Needle seems to be hitting the plate and sounds
sounds like the sewing head is out of line. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 10, 2010 | Husqvarna Huskylock Computerized 910
Huskylock 910
Always turn the handwheel towards you. There may be an arrow on the side. (Looking from the right it should go counter-clockwise)
Unthread the needles.
Make sure that the needles are new or good (not old or bent).
Make sure that the needles are inserted with the flat side to the back and all of the way up. The left needle will be higher than the right.
Make sure that the loopers are correctly threaded and under the foot.
Place the needles in the highest position and rethread the needles.
The loopers MUST be threaded before the needles in order for it to sew.
Make sure that the threads are pulled fully down into the tensions.
Jul 26, 2009 | Husqvarna Huskylock Computerized 910
Husqvarna 910 won't create a chain.
You may have knocked the machine out of time if the machine does not pick up stitches.
Jan 21, 2008 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
61 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
