Question about Napoleon Pool & Spa
How to install wires to thermostat on Napoleon GDS50 stove
I installed the GDS50 (propane converted) stove and it works great, but when I changed the wires to a thermostat, it will not light. The manual said switch out wires on posts 1 and 3 (the original wires were on 1 and 2) but either way it will not ignite the burners?? What am I doing wrong? It's just a 2-wire hook-up to the on/off switch.
  • terrywclee
    terrywclee Jan 06, 2013
    Hi, I am researching to do the same thing. Did you fix the problem? thanks
catriver
  • 878 Answers
SOURCE: STOVE TOP CONTINUOSLY SPARKS
Thrasher, Sorry I cant help with the diagram but one of your burner switches is grounding out. Each burner valve has a switch and one of them is finding it's way to ground, therefor the contstant clicking. Good luck on this deal...Catriver..post back.
Posted on Sep 07, 2006
  • 93 Answers
SOURCE: Ignitor on burner #2 keeps clicking even after burner #1 lights
Jenn Air uses a reignition system on their gas cooktops.It is very important that you have a well grounded recepticle. Please check that and please get back to me.
Posted on Oct 29, 2008
  • 10865 Answers
SOURCE: stove trips breaker
Begin by unplugging the pellet stove and using an extension cord, plug the pellet stove into a different circuit, with a different breaker. It is possible that the breaker itself is faulty. If you prove that the problem is in the breaker, replace it. If the new circuit also trips, then you will have to assume that the stove cord, or the stove mechanism is faulty and either repair or replace it. good luck with it. let me know.
please mark this answer as a fixya! ty.
Posted on Mar 11, 2009
  • 10 Answers
SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Posted on Mar 16, 2009
SOURCE: Ignition switch
A kubota dealer should be able to print one for you or go on line with model # etc and you should be able to bring one up yourself. I hope this helps. donnyb60
Posted on Mar 19, 2009
I have propane. Is my range set up fpr natural gas or propane and do i need to change. I'm having issues with my oven
without knowing your model number or mfg it's tough to say 4 sure but i can say that most common mfg do offer a propane conversion kit to use there gas stoves on bottle gas , most often it's a new regulator to install
Jan 08, 2015 | Kitchen Ranges
Purchased a used Earth stove mp240 pellet stove and the auger does not move. we are looking for a manual or information on this stove it is an older stove we just don't know how old. Thank You
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Jun 10, 2009 | Napoleon Auburn Pellet Stove Heater
How to convert from natural gas to propane
All stoves in this country come from the factory with orifices designed to use natural gas. To switch over to propane, the orifices have to be changed over. Contact your propane provider and they will obtain the proper orifices for your range. They may even install them for free. good luck.
Feb 18, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Propane conversion
All gaq cooktops come from the factory ready to be installed to natural gas. If the only gas available is propane the orifices have to be changed. The orifices are product specific and must be ordered for your particular stove.
That being said, if this is a new cooktop you have the answer. If this is a used cooktop and you do not know which style of orifices are installed now just contact your propane company and they will be happy to help you for free.
good luck with this. and please remember to rate my answer.
Feb 12, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
My new gas stove (propane) is releasing black soothe when lit. All the pots are covered in this black powdery like substance. Whats the problem and how can i fix it. It's really costing me a lot to clean .
All gas stoves are set up for natural gas. Before using on propane, the oven and burners need to be converted for propane operation. Refer to the installation manual for conversion requirements for your particular stove.
Dec 25, 2008 | Kitchen Ranges
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Pool & Spa Logo
236 people viewed this question
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Craig Butler
Craig Butler
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
