Question about Brother XR-65t Mechanical Sewing Machine
I forgot how to install my bobin
I have moved and lost my instruction booklet and forgot how to put my bobin in correctly. It's been a long time since I have used it. Please can someone help me? Thank You.
    President:
  • 2,976 Answers
Hold it in your right hand by one of the flat sides. The thread should come off the top of the spool going away from you. Lower it into the bobbin hole and replace toe top cover.
Posted on Jan 05, 2009
The bobbin case is not threading up???
cases do not thread bobins do when outside of the case and usually on top of the machine. then put into the case and put back in case holder
Jun 24, 2016 | Sewing Machines
Sewing machine problem
if the bobbin winder spindle will not return to it's original position, then there's a part in the machine that not working correctly, & it needs to be serviced,
Feb 27, 2012 | Husqvarna Sewing Machines
I CANNOT PICK UP THREAD FROM BOBIN TO NEEDLE. I HAVE CORRECT THREAD ON MACHINE AND BOBBIN-BOBIN IS IN CORRECT NEEDLE IS CORRECT. THE MACHINE I HAVE IS THE 3230 ELNA AND it SEEM TO BE SOMETHING WRONG WITH...
* Try to hold the end of the top thread towards to the back of the machine while you turn the hand wheel towards you .* Have the tension on top set to four.
* Check the bobbin tension. It should be set to set to four. This is an equivalent pull with the above tension.
*If this doesn't work the machine will need to be "timed" properly. Your local repairman can help.
Sep 04, 2017 | Elna 3210 Mechanical Sewing Machine
Hi where can i download or if there is a website i can down load a free user guide instruction booklet for my janome 6500p pdf for free i recently lost mine when moving house
You can download the instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 05, 2010 | Janome Memorycraft 6500P Computerized...
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
I have a rs2000 sd/u series and l am having problems after a needle snaped it will not pick up the thread from the bobin case
Check first that you have put the needle in the correct way round, if that is okay then you will need to retime the machine, I can attach timing instructions if you email me and remind me of your machine and letting me know if your bobbin drops in or goes in a seperate bobbin case drivewithken@blueyonder.co.uk
Oct 25, 2009 | Toyota Sewing Machines
MITSUBISHI DB 130G threading instructions
I am looking for a manual for the Mitsubishi relsew DB-130. I need to know the best way to thread the bobin and the correct way to put in the needle. I will take a photocopy of the manual if someone has one?
Aug 02, 2009 | Sewing Machines
Instruction booklet
I was just checking the web for information on my machine, the Janome 5018 and ran across your post. I have an instruction book, if you are still in need of one, you may email me at:
splitingstitches@yahoo.com.
joanne
Oct 25, 2007 | Janome D'cor Excel 5018
Brother XR-65t Mechanical Sewing Machine Logo
59 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
