Question about Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft. Super Capacity Electric Dryer, Arctic White, Electronic Control Panel, iCare Intelligent Fabric Care AEQ6000ES AEQ-6000ES AEQ6000-ES AEQ6000 AEQ-6000
My Frigidaire Affinity Dryer won't heat up element good just replaced the thermistor and also the fuse only thing left to replace is the Thermal High Limit... but tested that and it was good any t
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Are you sure you have 240V going to the dryer?
Posted on Nov 06, 2012
hunter19_46m
  • 7482 Answers
SOURCE: Frigidaire Dryer GLER341AS2, tumbles but not heating
I would say your right on track, check your heating coil when you locate it also...just in case.
Good luck,
Hope this helps...
Posted on Oct 06, 2009
  • 240 Answers
SOURCE: frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
Posted on Jul 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: how to replace fuse dryer frigidaire affinity
If it is like any other frigidaire dryer it is mounted on the upper right hand corner of the rear bulkhead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 09, 2009
  • 410 Answers
SOURCE: My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
  • 401 Answers
SOURCE: Frigidaire Dryer not drying clothes properly
TRY DISCONECTING THE VENTING FROM THE BACK OF THE DRYER THEN RUNNING IT .POSSABLE THE OUTSIDE FLAPPER STUCK?IM THINKING NOT THE DRYER. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Jan 16, 2010
Dryer wont dry clothes affinity front loader
Hi Jill,
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Oct 19, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryer won't start. it doesn't do anything at all when i press the start button
Hi wawhitlock20...
Check your Wiring
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
Please take time to rate me thumbs up
Sep 18, 2011 | Frigidaire FDE216RE Dryer
Our frigidaire gallery dryer won't heat up. It turns fine, and we have tried it on multiple settings.
Hi mommylein...
Check your Wiring
Sep 17, 2011 | Frigidaire Electric Dryer
My frigidaire dryer is not coming on
Hi samantha sis...
Check your Wiring
Sep 15, 2011 | Frigidaire Dryers
My frigidaire dyer is not getting hot but its still tumbles the model # GLER341AS2
Hi keke1981...
Check your Wiring
Sep 06, 2011 | Frigidaire Electric Dryer
Clothes are not being dried even after an hour (Frigidaire heavy duty)
Hi kansokhi...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Aug 23, 2011 | Frigidaire Electric Dryer
Dryer powers on but won't heat up
Hi montoya122...
Check your Wiring
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
This is a FREE answer, Please take time to rate me
Jun 22, 2011 | Frigidaire Dryers
The dryer runs but has not heat.
Hi joe marvin...
Check your Wiring
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
For video and pictures on how to replace the element go to the following website:
May 19, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Replaced thermistor & thermal limiter still no heat on an affinity 7000eg series dryter
check the element,then the thermal fuse on the dryer vent housing by the exhaust outlet on the rear or on the blower housing on the dryer
May 05, 2010 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire Affinity dryer error code?
you have a problem with the heat you can't just say it's the element or thermistor you have to unplug it,take it apart and get in there with a meter and check all the t-stats,element thermistor,if they check good you could have a bad computer board but hopefully it will be the element but if you just bought it the dryer is still under warranty for the first year so either call whoever you bought it from or the 800 number off of the machine
Jan 02, 2018 | Frigidaire Dryers
Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft. Super Capacity Electric Dryer, Arctic White, Electronic Control Panel, iCare Intelligent Fabric Care AEQ6000ES AEQ-6000ES AEQ6000-ES AEQ6000 AEQ-6000 Logo
832 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
