Question about Mitsubishi Televison & Video
New lamp for mitsubishi mod. wd-62628 will not go in to match up as old did. new lamp #:915po26010
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
With the lamp removed (a common issue here) look to see the 2 pin socket the lamp engages did not get bent or moved to one side--if so it has to be got at from inside and the rear-----one tiny screw usually holds it in place----you should be able to see if socket with lamp out is in correct position or NOT.
Posted on Nov 06, 2012
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
IrishDruid
  • 2712 Answers
You most likely have some faulty capacitors on the power module. You can easily identify a bust capacitor. They will have swollen tops. Here is a sample pic:
Check the specifications of the faulty capacitors, and getthe replacements from your local electronics shop. If you are comfortable withthis, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out thedefunct capacitors. Once that is done, solder in the new capacitors carefully. Ifare unsure how to do this, try to get a friend who knows this kinda stuff to doit for you, or get a qualified technician.
Warning: If you do not have a background inelectronics repair, or are inexperienced, get a qualified technician to do itfor you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
If you want to go in for a long term solution, youcan easily replace the whole power board. You can get spare from HERE.
They also offer FREE online technical advice as you do the DIY..
Hope that helps!
Posted on Oct 06, 2008
ginko
  • 19396 Answers
SOURCE: WD-62628 Mitsubishi DLP
Here is the picture for a Mitsu62525 power board, which is similar.
You recognise it because you get power cables innesting into the power board.
If you decide to work on your TV, get the service manual first.
Posted on Oct 10, 2008
localwonder
  • 6784 Answers
SOURCE: wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Posted on Sep 02, 2009
ladywinn
  • 5138 Answers
SOURCE: I just replaced a 915P026010
Is the Lamp Fan running ?As far as that goes is all Fans running and have you Pressed reset button?
Posted on Dec 17, 2009
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
Installed new lamp but her static sounds wd-73733 and still no picture
I would venture to guess the bulb figment is your issue and the electrical sound is most likely arching (very bad). The cheap replacements won't last. I bought a sylvania build and matched the model number with the one from inside the old bulb housing. Changing out the bulb from the casing is really easy so just return the one you bought and buy the corresponding bul without the case.
Jun 26, 2014 | Mitsubishi WD-73733 73" HDTV
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
I recently replaced a 915P026010 bulb for a MiTSUBISHI WD-62628 tv and it gives me a blinking yellow light in the lamp led indicating that the lamp housing is not installed properly. I have re-installled...
Make sure lamp cover is also fixed on tv cabinet after lamp installation.
If lamp cover has not been put on its place, tv wont turn On due to safety switch inside that place that gets press with lamp cover.
Thanks.
Jun 24, 2011 | Televison & Video
I removed the lamp cartridge from the back of my WD -62628 just fine, but cannot insert the new cartridge, not aligning properly and won't go all the way in. Even the old cartridge won't go all the way...
you've got to get a bright light and a mirror if needed to see what is in your way. if the old one won't go back in then something is blocking you out. did you have to get any special angle to remove the original? it may only go in one way and take your time and try different angles
May 01, 2011 | Mitsubishi WD62628 62" Projection HDTV
Mitsubishi tv model wd-62628
It's most probable that you have a ballast issue, it might not have enough power to keep up with the new lamp. That's why you don't get any image.
Aug 10, 2009 | Mitsubishi VS-50605 50" Rear Projection...
No picture after changing lamp, tv will not power up.
Try bringing up the menu. If you can't I'd suspect the fmt board if you can suspect the dm module.
Bill
Nov 24, 2008 | Mitsubishi WD62628 62" Projection HDTV
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
