Question about Brother Office Equipment & Supplies
Brother 8360P fax remains in sleep mode. I have tried reprogramming the sleep timeout to "0" Still no luck
  • 1 more comment
  • allan_bailey Jan 05, 2009
    Tried the suggested solution. No joy!
    The machine journal reports a random tx and rx error and will only perform as expected immediately after warming up after a power 'off'
    The suggested solution is straight from the manual. I have a manual and have read and implemented the instruction.
    I believe the problem requires a solution other than standard. Is there any history/experience from other users?
    Thank You
    This seems more like the problem. Its apparently not something simple. I will take your advice and call a service techo.
    Scholar:
  • 107 Answers
Can you reset the settings to factory/default? My next thought is that this is an indicator to call for service.
Posted on Jan 05, 2009
    Genius:
  • 2,035 Answers
Try to reset the fax machine to factory defaults ,and check if the it works
    Sergeant:
    Novelist:
  • 326 Answers
The machine has the problem of not coming out of the particular mode as it reaches in the stand-by mode.there is a small cmos battery on the main board that has to be removed but it is tightly fixed and not very easy to remove .removing that cmos battery and re-entering will wipe all the error details entered and you can set it again as you wanted.as the cmos battery is on the main board you will need to open the machine and thats very risky and dangerous so calling a service tech is much advisable.
    Sergeant:
  • 378 Answers
Setting the sleep reduces the power consumption ,by turming off the fuser inside the machine ,while the machine is idle .you can choose how long the machine is idle (from 00 to 99) before it drops in to sleep mode .the timer automatically resets when the machine receives a fax or makes a copy.the factory setting is 05 minutes .while the machine is in sleep mode you will see sleep in the lcd .when you try to print a fax/list there will be short delay whilst the fuser warms upto working temprature  :----- 1)press menu -- then 1, then 6. 2)use the dial pad to enter the amount of time the machine is idle before it drops into sleep mode (00 to 99). 3)press set. 4)press stop/exit. this is the exact procedure and will definately help if followed properly. thasnks.
  • 565 Answers
Set the sleep mode to 99 and set the powersave to off
if it helped rate fixya if not then make a clarification
  • 4,472 Answers
First off, how long have you owned the unit? Also how long have you been having this problem? Once I have more information I can assist you further.
Thank you,
Lee
Where is the on/off switch on a brother fax 8360P
Thereisn't one, you just plug/unplug at the mains.
Jul 10, 2014 | Brother FAX-8360P Plain Paper Laser
Brother 8360p has faxes in memory but will not print them. All the faxes ar going into the memory now. It has paper and toner, check by making a copy. the menu 2 5 4 fax command doesn't do anything,...
I have seen a few Brother faxes do this. I fixed them by turning off the power, holding down the clear/stop button and keep holding it down while you turn the power back on. Keep holding it for a few seconds then release. This will clear what ever is in the memory that is locking up the memory print. Note: you will lose any received faxes in memory by using this procedure.
This may help you restore your fax to a operation condition.
Good Luck and Thank You for using Fixya.
Aug 19, 2010 | Brother FAX-8360P Plain Paper Laser
I need driver for win7 for my brother fax 8360p
not avable from brothers as yet. keep checking windows web site for drivers.
Aug 10, 2010 | Brother FAX-8360P Plain Paper Laser
How to stop sleep mode?
Sleep Mode
Setting the Sleep Mode reduces power consumption while the machine is idle.
You can choose how long the FAX/MFC is idle (from 00 to 99 minutes) before
it drops into sleep mode. The timer automatically resets itself after the machine
receives a fax or PC data or makes a copy. The default setting is 0 minutes.
1 Press Menu/Set, 1, 7.
2 Use the Dial pad to enter the length of
time the machine is idle before it drops into sleep mode (00 to 99 minutes),
and then press Menu/Set.
3 Press Stop/Exit.
Dec 01, 2009 | Brother IntelliFAX 2800 Laser Fax
UNABLE TO REMOVE SLEEP MODE
you can't take it off of sleep mode. the only thing you can do is set it to go into sleep mode anywhere between 0 to 99 minutes. you do that by pressing "menu, 1, and 8." there, you can input how long you want sleep mode. no way of completely disabling. i'm thinking that somehow, it must have gotten set to 0 minutes.
hth,
razors
Mar 30, 2009 | Brother IntelliFAX 4100 Laser Fax
Sleeps to often
WHEN YOU AREW NOT USING THE FAX MACHINE FOR AWAHILE IT GOESE INTO MODE, PUSH ANY BUTTON TO WAKE IT UP, THE SAME FOR INCOMING FAXS IT WILL WAKE UP BY ITSELF., GOOD LUCK
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Our fax doesnt want to recieve it sais sleep mode
have you tried to turn it of then on to reboot the fax machine! if that will not work you may have a bad main board
Jan 10, 2009 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Clearing memory Brother 8360p
Press quickly......MENU 2864 then press 91
Oct 16, 2008 | Brother FAX-8360P Plain Paper Laser
Disable sleep mode
To change the sleep mode: Press Menu Numbers 1, 8. From your key pad select the amount of time before the fax goes to sleep. 0 - 99 Press Set Press Stop/Exit You can find the user manual here for the future if you would like: http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000082/FAX4100_US_UG_0.pdf Hope that helps... Lbcoaster
Jun 27, 2008 | Brother IntelliFAX 4100 Laser Fax
120 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
