Question about Bose Lifestyle Model 5 Music Center
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
    Problem Solver:
  • 9 Answers
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Posted on Nov 06, 2012
techman
  • 3130 Answers
SOURCE: lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Posted on Jun 14, 2006
CLARKPINK55
  • 71 Answers
SOURCE: Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Posted on Dec 10, 2008
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
cjackHD
  • 71 Answers
SOURCE: Bose Lifestyle 48 System play's dvd in black & white only
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
Posted on May 31, 2009
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
How do we connect the Bose Lifestyle Surround Sound System to a Samsung television? When we have tried there is no sound, but when we put in a CD into the music unit it does work. Any thoughts?
Go to your TV's settings and change your audio output from TV speakers to Auxillary, or whatever port you have it connected to. It should be under the Sounds tab.
Sep 14, 2014 | Bose Audio Players & Recorders
Not good surround sound Is the bose lifestyle 5 support 5.1 surround sound?
The Bose Lifestyle 5 is not a 5.1 surround sound system. It is a 2.1 sound system, meaning it is stereo with a subwoofer/bass unit. Having two speakers that can be angled in different directions, the Bose Lifestyle 5 employs Bose direct/reflecting technology,providing greater audio presence. Still, it is definitely not a surround sound system.
Jan 24, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
Problem with Airport express to BOSE Lifestyle
When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
anybody got a solution??
Alex, Sthlm
Jan 20, 2010 | Apple AirPort Express with Air Tunes
When watching a DVD, the surround sound plays all background music but the actors voices are not heard - can hear music and voices in 2 speaker only - TV programs play in 2, 3, and 5 speaker mode.
If there is nothing at all from the center channel while watching a DVD, first try resetting the system (unplug the power cord from the sub, and the DC power cord from the media center for 30+ seconds) If a reset doesn't help this, run the "adaptIQ" setup disc again. Honestly, this is a very odd problem for that system to have. (especially since we know the center speaker works for other sources) I hope this helps.
Jun 20, 2009 | Bose Lifestyle 28 System
Can i use my lifestyle 5 to other cd player?
Yes. But you need your Model 5 music center connected. Just like any receiver. -Without the main LS head unit, this will not be able to turn on.
May 28, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
BOSE 38-WHITE BACK:ERROR 801-LOUD SCRITCHING NOISE AFTER SHUT OFF
Hello any cable or satelite tv show is now more comonly in high definition sound and video! and the techs are wrong because their are plenty of movies on tv including news channels that broadcast in surround sound ,but in order to get that surround sound you must either have a connection from the tv,s audio out or you can also out put the sound from the cable or satelite box out to your bose system as as the scritching sound where does it only happen when in surround mode or stereo mode ? if you play a dvd or cd does it still make noise? and can you be more specific on your terminology SCRITCHING not really shure what you mean by that word! thank you glenn mayer
Mar 06, 2009 | Bose Lifestyle 38 System - white Theater...
Dec 10, 2008 | Bose (321GS) System
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Dec 01, 2007 | Bose LifeStyle 5 Series-III CD Shelf...
Lifestyle 12 by Bose
Jun 14, 2006 | Bose Lifestyle 12 System
Bose Lifestyle Model 5 Music Center Logo
685 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
