Question about Sansui Audio Players & Recorders
I have an old Sansui au999 amp
1.I would like to hook up my amp to my TV. On my amp I have tape in, tape out, phono and aux. To hear the TV through the amp, how should I hook up rca cables?
2.I have a DVD, how should I hook up the DVD to the amp?(tape in, tape out, phono or aux?)
  • Anonymous Mar 18, 2014
    It has a aux cd phono tape etc
You can go about this many ways.depending on what you have to work with.are you useing a satilite or cable box?if so assuming they have audio/video out just send the audio to the amp and the video cable to the tv.u could use the aux or the tape in.just put the dvd in the other input aux or tape in.dont matter which.if you dont have a cable box your tv must have some kind of audio out to run to the amp.it can be a rca out or simply a headphone jack.you will need a headphone jack too rca plug cable if you have a headphonejack on your tv.hope i could be of help.
Posted on Jan 05, 2009
How to hookup sansui SE-8 eqalizer to sansui AU719integrated amplifer.do i use the tape side or there are 2 phono inputs? I would like to know if it will control tuner aux. which is my cd player as well
PHONO is ONLY for TURNTABLES. That's why they don't call it AUX.
Wired as I described in the other request, the EQ will have effect of anything that amplifier uses for input once you engage the tape loop the EQ is installed on.
Mar 24, 2011 | Audio Players & Recorders
Sansui 2000x Phone 1 and 2 inputs produce garbled sounds.
I imagine everything is also VERY LOUD.
Only a Phono (old school turntable) should be plugged into the Phono inputs. It contains a preamp for the tiny signal provided by a Phono cartridge, plus is alters the frequency response drastically to compensate for the RIAA curve applied when they cut the record from tape.
Mar 26, 2010 | Audio Players & Recorders
How do i hook up my i pod up to a mcm530 philips stereo system?
If it has an aux imput all you need to do is get a dock (which will keep the battery charged while playing) or the cheaper way - by connecting a 3.5mm plug to two RCA phono plugs- lead. The 3.5mm plug goes into the headphone output of the I-Pod and the RCA's go into the Aux imput of the Philips.
It can be any imput on the amp (except phono) such as CD or tape.
You will find that you need to turn up the volume on the I-Pod to hear the sound.
Mar 08, 2010 | Philips MCM530 CD Shelf System
I have not been able to record LP's. The instructions mention hooking up the cables to the receiver outputs down to the TDK deck. Which outputs? Tape, Aux,? I tried splitting off of my phono outputs with...
your phono outputs are a whole diff ball of wax than aux or tape etc, whole diff signal, all that they should run to is phono in on the receiver. You are using the cd recorder as a tape deck more or less, so use tape out to line in on the tdk, and tape in from tdk output. so..when spinning record, you have receiver set on phono, and the tdk should also be receiving that signal, to playback you would hit tape monitor button on the receiver and hear what the tdk has done, or is doing.
Feb 01, 2010 | TDK DA-5900 2-Disc CD Recorder
Hooked it up but sound is very low. Has a ground
Didi you try to change the middle. that was what was wrong with mine
Jan 13, 2010 | Audio Players & Recorders
How to hook up a sansui classique 350 reciever to a tv
Are you wanting to play he audio from your tv through you Sansui Stereo. If you have audio outs on you tv then connect them to the aux input of the receiver. If you ae using a cable box r sat reciever you can connect the audio out from these devices to the aux or any input other than phono input of your Sansui receiver.
May 01, 2009 | Televison & Video
When I hook up the RCA cables from the Phono to minimal volume
PHONO requires a phono-equipped receiver, which the STR-DE598 appears to NOT be. AUX will not work because it requires Line Level inout. Traditional old-school turntables put out a very tiny drastically-altered signal which needs preamplification to raise it and flatten it out for use by downstream circuitry. THAT is the job of the PHONO section in a preamp or receiver. You need to find a phono preamp or an older receiver to run the TT through. You could slave it to the STR through its AUX then.
Apr 30, 2009 | Sony STR-DE598 Receiver
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Aug 30, 2008 | Audio Players & Recorders
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
379 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
