Question about Fisher Paykel Fisher & Paykel WL37T26CW2
High pitched squeal - Fisher Paykel Fisher & Paykel WL37T26CW2
  • Fisher Paykel Expert
  • 554 Answers
Your pump bush needs silicon spray.
Posted on Feb 09, 2013
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
High pitch squealing when i turn on fan
bearing gone or rotor blade scraping against outer cover
Dec 12, 2013 | Lasko 3520 20-Inch Cyclone Fan
2004 trailblazer ext high beam headlights wont turn off and the relay makes high pitched noise
Need to check the ground path on the squealing relay. A poor ground will cause this condition.
Feb 27, 2013 | 2004 Chevrolet Chevrolet TrailBlazer EXT
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
Breaks have a high pitch squeal when i break ata any speed. got breaks checked out and mechanic saidneverything was fine
A high pitch squeal is typically normal. However I have NEVER liked it.
I would replace your brakes with a higher quality brake pad, and see if you still have the problem.
Your pads can squeal when they are getting low, i would also get a second opinion on the condition of the pads.
Jul 16, 2011 | 2006 Chevrolet Aveo
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
1994 nissan pickup high pitch squeal when driving
it could be the engine belt or the brakes are bad listen to where it coming from and you will know which you have to change
Aug 18, 2009 | 1994 Nissan Pickup
High pitched squeal
It most likely is a worn brake pad. Clutch will tend to slip with out any squeal since it is a wet clutch. Try applying the front brake then the rear brake to determine which is squealing. Pads are about $45.00 per wheel, I just did mine friday.
Mar 16, 2009 | 2004 Harley Davidson XL 1200 C Sportster...
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
Fisher Paykel Fisher & Paykel WL37T26CW2 Logo
Top Fisher Paykel Washing Machines Experts
marlin siecinski
Greg Stephen
Greg Stephen
Paul P
Are you a Fisher Paykel Washing Machine Expert? Answer questions, earn points and help others
