Daewoo won't read remote
I have an old, secondhand Daewoo TV (I can't find a place on it that says what number it is) that won't respond to the remote. Or my brand new universal remote bought to replace it. Both remotes have fresh batteries, and according to that camera trick I just found here, the remotes are actually sending a signal. The TV just doesn't seem to be getting that signal. I've made sure that nothing is blocking the little recieving dot and have tried different distances between the remote and TV.
Please help!
  • chocolate_ci Jan 05, 2009
    But what do I do with the codes? The TV isn't responding to any remotes, and it is the TV's fault, not because I don't have the right code.
    Oh yes, it did. I've had it for 4 years and it worked just fine until about 6 months ago.
  • 837 Answers
Try these codes 10451, 11661, 10092, 10672, 10019, 10623, 10039, 10661
Posted on Jan 05, 2009
  • Jay Glendenning
    Jay Glendenning Jan 05, 2009
    Thats a component problem, do you know if it worked prior, you state that it is "second hand"
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Automatic channel scan on daewoo tv
What is the exact model number to your Daewoo TV?
Apr 23, 2012 | Daewoo Televison & Video
Need the remote code for controling a daewoo tv
Hi
The remote code for controlling your tv can be found in your remote's instruction booklet.
1. Turn on your TV,press and hold the CODE search button until the indicator light illuminates.
2. Enter the code using the number buttons,The indicator light should turn off
3. Then your tv should respond immediately to show that the code is correct.
THANK YOU
Jul 13, 2010 | GoVideo Go Video DVD/VCR Combo
Old daewoo tv, cant get my xbox to work on it, no
www.remotes.com has a substitution for the original remote. Unfortunately you will have to have a Daewoo remote to get it to switch over. Thanks
Nov 10, 2009 | Daewoo DTQ-29S1FCN 27" TV
Remote codes
http://www.oneforall.com
Hope this helps.
Len
Feb 27, 2009 | Televison & Video
Code for a tv remote
if u have a universal remote and none of the codes seem to work after trying all the codes and non still don t work follow these steps
1. make sure the power on the TV is turned on
2 press and hold code button until it flash twice
3 then press the TV mode button until the light flashes the press
4 power button until TV powers off
Feb 13, 2009 | Daewoo DTQ-20U4SC 20" TV
Here are some Universal Remote codes for Daewoo TVs:
GE Universal Remote: 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058 0017 0010 0126 0018 0127 0019.
Philips Universal Remote: 0614 0002 0502 0611 0102 0415 0905 0615 0505 0826 0529 0046 0609 0805 0407 0303 0602 0214 0403 0314 0503.
One For All Universal Remote: 0451 1661 0092 0672 0623.
RCA Universal Remote: 1004 1005 1006 1016 1017 1082 1171 1190.
Innovage Universal Remote:004 005 009 017 018 019 042 058 082 085 097 100 126 127 130 138.
Verizon FiOS TV remote 0478 0119 1688 0650 0688 0699.
Feb 13, 2009 | 1999 Daewoo Nubira
Trouble Finding Code
Have you tried the code search option:
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Have you also tried the other daewoo codes -
Daewoo 011,019,027
Nov 25, 2008 | Hitachi C1424T 14" TV
T.v and universal remote
i have a remote it is a rca and it is being used for a Daewoo tv.I need the code/model number rcr311
Dec 20, 2007 | Daewoo DTQ-20U4SC 20" TV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
