Question about RCA 24F512T 24" TV
When I turn on my internet and TV with the universal remote the Guide Plus menu comes up as well and we can't get out of it without turning the TV off then on again manually. Is there anyway to program the TV to just come on without this menu popping up every time?
1. When you cut on you tv the guide pops up.
2. On the tv remote there is a button that says "menu" hit that and the screen should go away, i just did it myself because i have my tv program with that Jumbo Universal Remote Control and just ran into that problem.
3. How to just program it out of the tv when its cut on all together, im on the hunt for that answer myself.
4. Try going to manufactures website and try trouble shooting for your make and model, that is what i am about to do right now. Cable tv has the guide so i don't need my tv to pop up its guide also.. you now.. good luck
Posted on Jan 10, 2009
Proscan universal remote control Codes List
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Dec 26, 2013 | GE Original Crk17tb1 Guide Plus Gemstar Tv...
How can I turn off guide plus so it doesn't come on everytime I turn on the TV? I think This is the model#
Hi my name is Eric,
I can help you with your issue ,
Using the original remote enter quide plus menu , under setup tab look for general and set the default to off.
like a little on/off switch it turns off the guide plus
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Oct 06, 2009 | Proscan PS36700 36" TV
Guide Plus keeps popping up when the remote is used to turn TV on
there should be a way to turn it off in the user menu. usually it's under setup.
Jan 10, 2009 | RCA Universal Remote Control
How do I remove the guide plus from coming on at power up?
I found the solution!
With the remote, press the Guide button. This should bring up the Guide Plus+ screen. Press the right arrow to move the cursor all the way to set up and it will ask, "What would you like to do?" Arrow down to "Review Options" and press OK.
The first question is, "Guide Plus+ System Auto Display? On / Off"
Arrow down to Off and press OK.
Jan 01, 2009 | GE 32GT740 32" TV
Turning off PIP without remote
order the origanal remote from www.vancebaldwin.com the part number is RM-C380-1A the cost is $24.22 plus SH. there are a hand full of universal remotes that can control PIP but getting the right one a **** shoot.
Apr 19, 2008 | JVC AV-20120 TV
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Rca tv f27628
http://sci.tech-archive.net/Archive/sci.electronics.repair/2006-12/msg01203.html
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Nov 11, 2007 | RCA F27628 27" TV
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Guide plus flashes on the t.v.. how do you turn it off
you are that clear
but if you are talking about flashes on the t.v then it is due to sparking is taking place in your plug & socket.
if it is ok then there is a sparking in high voltage section in tv which is called fly back section.
good luck.
Oct 17, 2007 | GE 32GT740 32" TV
RCA 24F512T 24" TV Logo
112 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
