Question about Mitsubishi WD-73735 Television
Green light keep blinking but not stay still on so tv can not be turn on.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This is called the blinking light of death in these sets---when power is removed from set and put back the light should blink for about 70 seconds and stop----it is the digital signal unit booting up.
About the only common easy failure for this is there are 4 caps on the power supply board that fail---they will be puffed up on top like photo attached.
Green light keep blinking but not stay still on so - 11_6_2012_4_01_29_pm.jpg11_6_2012_4_01_49_pm.jpg
Posted on Nov 06, 2012
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
  • 1153 Answers
SOURCE: My TV won't turn on. The Green light just keeps on flashing
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Posted on Sep 05, 2007
  • 1153 Answers
SOURCE: green light blinking, tv won't turn on
Look for DM board repair here in threads
Posted on Jan 04, 2008
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
Sep 22, 2009 | Sony (XL-2400) Projector Lamp for...
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Blinking green light, will not power up
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi WD-73735 Television Logo
248 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
