Stains my washing machine leaves black stains on all my clothes, how can i resolve this problem I have Simpson Espirit 550 washing machine. Recently the spin cycle is not working intermittently.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Washing machine, Simpson Espirit 500, won't start at all. Power is on and water, cold turned on as well.
Possibly the door switch isn't working or is maladjusted so the machine's brain thinks the door is still open.
Feb 18, 2017 | Simpson Washing Machines
Simpson eziset 550 leaves orangey marks on clothing after washing cycle completed
Orangey marks might be rust . possibly from the water or the machine . we can not see it from here . have a local tech look at it .
Feb 13, 2017 | Simpson Washing Machines
How do I remove the agitater from simpson washing machine espirit 550 5.5kg
most machines with verticle and turning agitators have a cap on the top which may be removed with a small ***** driver. that should give you access to dawgs and release nut. use a rubber hammer to gently tap and loosen if need be.
Apr 03, 2016 | Simpson Washing Machines
Oil on cloths after wash
Simpson washing machines are known for this, The seal in to top of the gearbox fails which allows water to enter the gearbox, this forces the grease out of the gearbox into the machine, The fix is an expensive gearbox swap.
Mar 11, 2012 | Simpson Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
Black grease spots on clothes after the wash I have a simpson espirit 750 washing machine
Hi just read your posting.Are you 100% sure the black marks are grease or oil?If you are then the only place the oil comes from is the gearbox.This means that to repair this fault you need a new gearbox.Unfortunately the repair is not cheap so I would recommend getting a service tech out to confirm.Every time I went to a customers house and I saw this problem then I would tell them the same thing.Once again sorry for the bad news and please reply if you need any more help or advice.Good luck.
Jul 11, 2010 | Whirlpool Washing Machines
My simpson espirit 700 has been in storage for
check first the continuity of the power cable. next is the fuse if it is not busted. then try to open the control portion there might be some coroded contacts.
Apr 07, 2009 | Washing Machines
Ruining cloths, leaves black stain.
Black stains could only come from rubber part that is deteriorating. Need to check all hoses, rubber boot and at bearing seal.
Dec 11, 2007 | GE WCVH6260F Front Load Washer
Washing Machines Logo
154 people viewed this question
Top Washing Machines Experts
