Question about Maytag Centennial MTW5800TW Top Load Washer
Maytag MVWC300XW0 spin cycle
Loud sound during spin cycle
SOURCE: My wash spins SO loudly
Had the same problem with my Neptune and is was not the bearing (there's only one). I replaced my washer with a new tub and bearing which was factory pressed in the tub (couldn't just by the bearing) after all this I found that the spinner support (which has three arms holding the tub) on the back of the tub had one of the three bolts broke and was throwing the washer out of balance and creating a loud knocking sound when it would spin. Replaced the stainless bolt and everything was fine. The repair man told me what he thought was wrong with my machine so I did the repair myself and found out after the fact that I wouldn't have had to spend all the money on the new parts if I would have just investigated the problem further.
Posted on Nov 29, 2007
duby1990
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
  • 85 Answers
SOURCE: LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Posted on Dec 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 17, 2009
  • 153 Answers
SOURCE: maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Posted on Mar 05, 2010
Maytag top load washing machine repair
It sounds like your Maytag (now owned by Whirlpool) Actuator needs to be replaced. Last year our Maytag Centennial top loading washer Model MVWC300XW0 would not drain all the water and cloths would be soaking still. Doing some online research, I came across some very helpful video regarding replacing your Actuator.
The only thing I would recommend to future installers is get your Technician Manual located just inside the case (front panel) first of your Washer. The Technician Manual is taped inside your washer in a plastic bag. Once you replace this Actuator part, I recommend that you run the Calibration cycle on your washer. It is needed anytime you replace a motor, motherboard or pump.
Here are two videos describing how to change/replace the Actuator but these videos are basically for the MVWC300XW0 model. I'm sure if you search for your model, there will be other videos as well.
Two videos on how to replace your Actuator:
1: https://www.youtube.com/watch?v=YVjTY-Hj4jw
2: https://www.youtube.com/watch?v=yTHryoT78pA (This is video that I viewed the most)
Best of Luck!
Jun 05, 2016 | Maytag Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
IUs very loud during spin cycle and you would
It appears Maytag no longer produces the type of quality product we have purchased since 1970... we've owned three Maytag Washers - our last "performa" is a piece of ****!
Dec 23, 2009 | Maytag Performa PAV2200
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Loud noise
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
May 20, 2008 | Amana NAV2335A Top Load Washer
Maytag Centennial MTW5800TW Top Load Washer Logo
202 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
