Question about SanDisk Sansa Clip MP3 Player
WMP 11 can't access files to sync with sansa clip
I get a message that says: Windows Media Player cannot access the file. The file might be in use, you might not have access to the computer where the file is stored, or your proxy settings might not be correct.
The files are not in use and they are on my computer. This happens all songs, even ones that I have sync'ed already. I have no problem, however, sync'ing with other devices.
  • koolgramps01 Jan 06, 2009
    The re-formatting worked. Thank you, catbird17!
    Problem Solver:
  • 14 Answers
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
Most other problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
Posted on Jan 05, 2009
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
When I download music and want to save to Sansa Clip, it saves in "shuffle" mode. The MP3 files are not in the order I want. I can't seem to make it stop doing that.
Sansa Clip user manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
When using Windows Media Player while synchronizing there is an extra option "Shuffle what syncs".
Page 14 of the pdf file [= page 12].
Seeing Sansa Clip in WMP on the left side:
1. Right click on the player
2. Select "Set Up Sync..."
3. Deselect the box "Shuffle what syncs..."
Sep 28, 2009 | SanDisk Sansa Clip MP3 Player
Hello i have a sansa clip 2gb and the music is showing up when i check the files but does not on the clip itself. it says "No song" I know i added the songs on there. can you help me?
try using windows media player to transfer the music...here's how 1.Update WMP to version 10 or 11 2.goto sync tab and yoyc player must be detected. 3.create a playlist of songs you want to transfer 4.click on start sync to transfer music to your player.
Sep 03, 2009 | SanDisk Sansa Clip MP3 Player
Downloaded books from the library won't play
I was having the same problem when I used Overdrive Media Console to transfer my audiobook files to my Sansa. I updated the license and retransferred and even tried changing the USB settings on the mp2 player. What finally worked? Using Windows Media Player to sync the files instead. When I hooked up my Sansa I chose "use WMP to sync files" and then I dragged/dropped the audiobook files to the mediaplayer window. The audiobook now plays without any problems since WMP made sure the files have the latest subscription update code.
Jun 01, 2009 | SanDisk Sansa e260 MP3 Player
Won't let me sync anymore
What i would recommend you to do is if you have windows xp to uninstall windows media player 11 and reinstall windows media player...if you already have 10 just upgrade to 11..
That should solve the problem
I hope that helps
Thank you
Mar 05, 2009 | SanDisk Sansa Fuze MP3 Player
Computer doesn't recognize MP3 player -
Try to reboot your PC. Leave mp3 player off when start Sync (if button lights up this time).
Jan 20, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Unable to put in music
You probably have your Windows Media Player set up to auto-sync - since this player is smaller than your total music collection, it is too much for both WMP and the Sansa. Disable auto-sync and you should be fine. Windows Media Player 10 is fine. Windows Media Player 11 works also.
-Tha Mp3 Doctor
Dec 23, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip synch problem
Make sure the songs you are trying to sync do not have DRM-encryption on them. Converting to mp3 format is the best way to make them sync-able. Otherwise, you can find DRM removal software.
Also, reformat the player in Windows Media Player 11 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Your player should be sync-able in WMP-11 now.
-Tha Mp3 Doctor
Feb 27, 2008 | SanDisk Sansa Clip MP3 Player
Can not view my music files on my laptop (but can on my desktop)
Get the latest firmware upgrade - this player wasn't originally designed with WMP 11 in mind. Also, make sure the laptop has the folders "My Documents" and "My Music" on it - this is primarily where WMP reads from.
Dec 06, 2007 | SanDisk Sansa c240 MP3 Player
Files on player are not listed in wmp or in windows explorer
change the settings of the player to MSC and connect the device to your computer. It will be detected as a removal disc drive. Open it and it should contain the folders in your player. IF you can only see a few folders. Click on Tools-Folder Option - Show hidden files and folders. Then you should see the folders that you have. Right click on the song and choose delete.
Aug 14, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
258 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
