Question about Ovens
Whirlpool wall oven goes pf stops working cools down and works again
Skill Will
  • 53 Answers
SOURCE: whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
Posted on Apr 02, 2008
SOURCE: F2 error, both ovens stopped working
F2 Flashing in My buttom Oven and had to shut the power off from the breaker to turn it off
Posted on Jul 24, 2008
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
fixyourboard
  • 310 Answers
SOURCE: F2 E6 on Whirlpool RBD305PDS14 double wall oven
Sometimes we see an intermittent electrical connection due to oxidation of the contacts on the keypad membrane tail. This can be easily cleaned so you can check this before investing in a new keypad. I posted some pictures and the procedure on our website. Here's the link:
http://fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html
Posted on Sep 20, 2009
Whirlpool cooling fan will not turn off ovens
There is a thermostat usually on the top or back of the oven which controls the cooling fan. When it cools down, the fan is supposed to turn off. I would say this thermostat has failed. Locate the thermostat and if its cool, the thermostat should be open circuit. If not, you will need a new one. Most spare parts centres should carry these. A generic or common oven cooling fan thermos will suffice if you cant get the genuine one. make sure the oven is off at the wall or the fuse box before you go into it.
Nov 19, 2016 | Whirlpool Ovens
My kitchen aid kebc208kss0 is getting the PF error in cool down mode.
\I am not sure y it is giving the PF code because that code is saying there has been a power failure. U could be right in the direction you are thinking.
Apr 26, 2014 | KitchenAid Ovens
Recieved a PF code and my oven will not work. Is there anything I can do?
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Feb 05, 2011 | Whirlpool RBS305PDS Electric Single Oven
What does pf on digital display mean? Oven will not work
PF means power failure.
This has caused a power outage to the oven.
This error can be removed by resetting the clock.
Hope this helps.
Thanks for using Fixya.
Dec 07, 2009 | Whirlpool Ovens
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Wall Oven not working
It is likely the Thermal Cut-Off (TCO) fuse, which for many Whirlpool ovens is located on the back of the unit. Turn the circuit breaker for the oven OFF first. You'll need to remove the trim on the left and right side of the oven (2 screws) and then remove the screws holding the oven in the wall. You can locate it easy enough by looking for the thermal fuse on any of the major appliance part websites. The test is simple enough if you have an Ohm meter, as it will be an open circuit if it is blown. There is only one fuse (normally) so if it is blown neither the bake or broil element will work. There should be a Tech Sheet located behind the control panel which will help, but if you don't feel comfortable doing this call a service tech.
Apr 02, 2008 | Whirlpool RBS245PD Electric Single Oven
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
