Question about Amana NED7200TW Electric Dryer
3 year old Amana NED 7200 dryer has film of black grease in drum back portion and grease is on clothes after coming out of dryer.
Just the last few loads, we noticed a piece of clothing, luckily not all, comes out with some black grease on it. I saw the back of the drum looked dirty and I crawled in to get a better look and it was a film of black grease. It was also on the grill that's on the back of the drum. Is this indicative of something failing? Is it something I can fix myself or is it a job for a professional? My last dryer was over 20 years old and never had that happen.
    Top Expert:
  • Amana Master
  • 9,472 Answers
Check the thermostats for continuity. Sounds like the dryer is getting to hot and may have melted something. There is nothing with grease in that area of the dryer,
Posted on Nov 06, 2012
SolutionGuy
  • 331 Answers
SOURCE: Amana gas dryer buzzes and won't start
Jeff, what you are describing is a drive motor that is locked up. The only cure for this is to replace the motor. This is probably the most difficult repair to perform on a dryer. You will need to have a lot of patience if you choose to proceed.
I looked up the motor for you, it's a part number 511629P and it lists for ~$145.00. That's alot of clams for a motor! And I presume this unit has some years on it, right? Which means that if you replace the motor, there's a good chance that another component will fail soon.
I'm not trying to dissuade you from a repair, I'm just mentioning possible options. But, if you want an opinion on this, mine would be to replace the dryer. I know this isn't what you wanted to hear, but I hope it helps you decide what to do.
If you choose to repair, write back and I'll do my best to walk you through the procedure.
Posted on Dec 24, 2008
SOURCE: Dryer will not dry - drum will not turn
Just happened to mine also. The problem was that the Idler Pulley came loose from the drive belt. There is a switch on the idler pulley so that if there is no tension on it, the motor will not start and you will have the symptoms you describe. To reattach the Idler Pulley, remove the back plate surrounding the dryer exhaust. This will give you access to the Pulley. If the belt broke (unlikely with a new dryer such as yours), the fix is more involved. This dryer is the same as the Maytag MDE6700 - you can do a search for a service manual for that model and you can see the details. Hope this helps.
Posted on Jun 04, 2009
dragonsthatk
  • 547 Answers
SOURCE: Dryer drum won't turn. It has power, the door is shut tight
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
  • 45 Answers
SOURCE: Dryer not heating up - Amana Model # ALG643RBW
Heating element
Posted on Apr 28, 2010
heatman101
  • 43501 Answers
SOURCE: Amana Clothes Dryer makes loud piercing noise when
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 18, 2010
Testimonial: "That answer was very informative - thank you for taking the time to educate me."
Dryer is leaving brown marks on clothes. it is either a burn mark or they are getting caught between dryer drum and shell, not the door
I had the same problem. Unfortunately, it is caused by a rusting drum edges, if you can believe it. My dryer was only 6 years old when this problem occured. There are felt gaskets on the front and back of the drums where it contacts and rotates on the frame of the dryer. You can take a white cloth and run it around the rim of the front and back of the drum and I suspect you will end up with some discoloration on the cloth. I had these felt gaskets replaced, but that is only a temp solution. When the drum is taken out and the old felt gaskets are removed, you can clean the edges of the drum and get a lot of rust/brown off the drum. New gaskets are only a temp fix. I did it about 1 1/2 yr ago, and I think the problem is starting again. Probably time for a new dryer or time to pull the drum and clean it. New drum probably cost prohibitive if you can get one. What a bunch of **** for a 7 1/2 old dryer. Next dryer will have a stainless steel drum. Hope this explanation helps you with your problem.
Steve
Mar 29, 2010 | Amana ALG331RAW Gas Dryer
Black grease stains on cloths, grease is coming out from one area in the drum. Whirlpool Calypso-6 years old. Is it worth repairing ?
Machine life is depends on the cabinet condition if the cabinet condition is good means you can service the machine it will be useful otherwise it is better go for exchange
If cabinet is good condition means you can use it for few more years also
Jan 08, 2010 | Washing Machines
Water leak. noticing water under the machine and we are certain that it is coming from the. Also, there we are getting spots of grease on clothes when we remove cleaned clothes.
without really looking at it i would have to say it Sounds like water seal gone in drum. If back of drum at the bottom is wet with black or dark run stains this is the problem.
Good luck
John
Sep 03, 2009 | Amana LWA40A
Grease marks left on clothes in the washer.
after parts replaced
you can still by a new drum and outer shell for that machine
main shell of washer
main shell plastic or metal
http://www.appliancepartspros.com/parts-for-amana-nav3335aww.html
grease may be trapped between inner drum and
if taking apart steam/pressure clean between the drum and internal
use full container of borax
use very hot water
and run an empty full load wash
95e11510-432b-415a-a332-4ca6f8fe25b9.jpg0028599314_6-cqwqmhrjackcqvld1tze14pd-2-2.gif
Apr 27, 2017 | Amana NAV3335A Top Load Washer
Black Film on the inside of the dryer drum. Transfers to clothes.
The gas is not mixing properly with the air. You could have a blocked or restricted vent which has caused lint to back up in the machine thus giving you a poor burn. Check your venting and if it is clogged you may need to dismantle the dryer to clean it out inside. :)
Apr 09, 2009 | Dryers
My Amana dryer squeals even with just one or two pieces in it?
Good Afternoon,
The drum support rollers are worn out. You have to remove the belt and drum to replace them. If you are fixing this yourself here is what to do: Get some light Emery Cloth and clean the roller shafts and wipe dry with a damp cloth. Get some "High Temp" Lithium Grease and grease the shafts and also the inside bushing of the new rollers. Be careful not to get any grease on the rubber roller or on the threaded end of the shafts. This procedure will give you many years of trouble free service. Please let me know if you need anything else. I hpoe I helped you today and thank you for using FixYa!
Mar 27, 2009 | Amana NDE2335AY Electric Dryer
Amana dryer belt?
Good Afternoon,
The main culprit here is the drum rollers, they need to be replaced and you have to remove the belt and drum to get to the rollers, so you might as well replace the belt also. If you are fixing this yourself do this: Clean the roller shafts with light Emery Cloth then wipe dry with a damp cloth. Get some "Hi Temp" Lithium grease, put it on the shaft and also on the inside bushing of the new rollers. Be careful not to get any grease on the threaded part of the shaft or on the rubber part of the roller.
I hope I helped you today and thank you for using FixYa!
Mar 24, 2009 | Amana NDE2335AY Electric Dryer
Dark grease stains on the cloths after drying
Most likely a bearing failure, a seal that retains grease has given up and is spewing into the drum through a shaft opening of some kind.
If you are positive there is no grease in some of the clothes, or someone is putting it in the drum, then a seal has failed, and now that the grease is coming out, the bearing it is was supposed to lubricate is now low, and will fail prematurely, you need a service call and soon.
Will
Nov 17, 2008 | Dryers
GE dryer, black grease stain on cloth
I have the same problem, I haven't resolved it but it seems to be due to the drum of the dryer being able to move more than it's supposed to and things getting caught in between the drum and whatever it sits in, at the front of the dryer. I have found things caught in there before and when I've pulled them out they had a brown/yellow grease stain on them. Other times something in the dryer will have this same stain - although no longer caught it seems it must have been caught at some point then became free again, with the stain. I'm thinking something is loose or if the drum is supported at the back by a bearing of some sort, this bearing may be worn down and the drum isn't sitting right.
Dec 19, 2007 | Dryers
Dryer putting black smears on clothes
The white plastic pieces just inside the font of the drum are the front bearings there are aboutfour of these, you will need to take the front of the machine to put them in, your clothes are probably picking up black smeres from where the plastis bearings have worn.
Oct 18, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Amana NED7200TW Electric Dryer Logo
124 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
