Question about Jenn-Air JED8430 Electric Cooktop
My jen air electric cooktop jd 8430 comes on but shuts off after a few seconds then comes on again, all of the burners do it and jus started doing it today
All of the burners cycle on and off and they just started doing it today. Is there a part that I need to replace
3 Suggested Answers
Eddie Rentas
  • 59 Answers
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
  • 222 Answers
SOURCE: One burner control stays on high even at full low.
hi...the unit is have an waranty call the service center to check & replace the part.
tnx gerbee
Posted on Sep 13, 2009
My jenn-air 8430 cooktop left front burner cycles off-on in the HIGH position. What could be wrong?
I am assuming your cooktop is electric and your have a glass top, if so the burners sensor is bad and you might need to replace the burner. Again before buying anything and for me to help you, I would need a full model number. Some model have plate sensors and with no plate/pot burner cycles. Most of the time I find the sensor in the burner cant detect the heat and this ends up being a safety issue to protect the unit. All this information is based on the premise you have an electric cooktop and a glass surface.
I hope this helps.
Oct 16, 2013 | Jenn-Air Cooktops
Heat shuts off after about 3 seconds, recycles
its not suppose to stay on for long time...its suppose to recycle...set it at high heat all burners should come on for few seconds and then go off for few seconds...small burner do faster then bigg ones
Nov 10, 2009 | Jenn-Air JED8430 Electric Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Draft
Someone suggested the flapper needs replacing.
Thanks for your help.
Jan 18, 2009 | Jenn-Air JED8430 Electric Cooktop
Keeps clicking after lit
your ignition button is sticking down after you press it to light the burners, give it a few taps and clean underneath the button.
Aug 23, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn air jed 8430 electric cooktop control switch for rear burner
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
Jen Air left front small burner does not heat up.
these are cartridge elements corrrect? try reversing the cartidges, now the front small will become the rear small . does it not work in this position? and the newly placed front burner work?? this will determine if the proble lies within the cartridge or the switches
Feb 22, 2008 | Jenn-Air JED8230 Electric Cooktop
Ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Oct 26, 2007 | GE Profile JGP636 Gas Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
42 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
