Question about Microwave Ovens
For a while, the microwave would intermittently work. Then we started getting "Sensor Error" on some modes. The microwave completely stopped heating, although the other features would work. We repl
We have visably inspected the magnatron, and it doesn't have any visible burns, etc.
    Top Expert:
  • Microwave Ovens Master
  • 14,553 Answers
The magnetron can look perfect but it or the inverter (power board) and a large diode often used usually cause this--all will look ok.....
Posted on Nov 06, 2012
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave works intermittently
This is most commonly due to a failing door switch or door switch mount. But it may also be a bad connection or bad relay on the control board, which we repair nationwide for $39.95. Also, it could be a loose connection at the magnetron. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams for similar models here: http://tinyurl.com/gv383 You can order parts at http://www.wehaveparts.com
Posted on May 22, 2007
  • 3 Answers
SOURCE: intermittant heating
You probably have a new unit by now. The Magnetron part inside usually is the problem with this Maytag unit.I have had this unit blow the 'Magnetron' four times ! Everything else works fine. After watching the technician, I replaced it myself the other 3 times. The whole unit has to come out of the wall to do this. This High Voltage part is dangerous. The part costs about $100.00 from an online parts store. Partselect.com- or someone else.
Posted on May 01, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Sensor Error, Funny Smell and Noise
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If none of these conditions apply to your situation, then you may have a defective sensor and/or magnetron.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Posted on Sep 06, 2008
heatman101
  • 43501 Answers
SOURCE: microwave cuts off after 3 seconds. Magnatron?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
  • 142 Answers
SOURCE: Sharp microwave oven works (lights,
First you need to make sure that all "normally open" door switches are closing when you close the door. Next would be the diode. That is a little black thing that runs from one of the capacitor terminals to the chassis. You should have continuity one way, but NO continuity when you reverse test it. It is like an electrical check valve so to speak. If that shows open both ways, or continuity both ways, replace it and you should have fixed your microwave oven. Of course there are a lot of other ways your oven does not work. Get back to me if you need more help.
Posted on May 27, 2011
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
NNCD997 Microwave Convection Oven
The magnetron may be intermittent or the keypad control board is the problem. My recommendation is to use it until it finally fails and go out and buy a new microwave oven, "more cost effective"
Apr 05, 2012 | Microwave Ovens
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
I have a sharp microwave sometimes it works for 10 or 20 seconds and then stops with error ee2, other times it works fine. Today it did the same but stopped with error ee1!
This sounds like a keypad problem, sometimes a short developes in the keypad controller causing all kinds of intermittent problems, on the back is the microprocessor circuit board which controls vital areas of the microwave oven. The cost to repair will be high and consideration should given to looking at a replacement.
Feb 17, 2011 | Microwave Ovens
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My Microwave keeps beeping loudly and giving me a sensor error! I can stop it, but it starts again shortly after!
1.tighten nut at sensor socket 2.check connections to socket 3.does error go away when sensor is used,if so probably bad socket,replace
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
